Coffee lovers
Interesting article, thanks for sharing, nice set up too. I look at these various means of puck prep with more and more amusement as time goes by. I'm not immune to being swayed by some of them though and I have narrowed it to three that work for me, WDT ( home made tool, wine cork and 3 sewing needles), Motta distribution tool and Reg Barber simple tamper. I don't use any other mechanical aids, competition baskets, filters, etc, etc. My extraction times are fairly consistent, I don't have much channelling (naked portafilter) and the flavour is good. I doubt my taste buds are sensitive enough to detect the n'th degree of a fart that these techniques give on extraction and I feel it's a balance of time faffing about and actually brewing the coffee. What I think is most important is the quality of the beans you use, good beans and careful ( but not over the top) puk prep are all that I feel is necessary.
Might have to grab myself one of these one day - my preferred method currently is the French Press - damn fine coffee every time! But if I were settled in a nice house, a real Italian coffee maker is a a step up for sure:
"Shaken, not stirred", very Bond!
Personally, I think it doesn't make scientific sense. If you tamper the puck then it'll condense the coffee right down. Shaking the coffee beforehand makes no difference....no?
This is my setup, minus the bean grinder.
Most machines are about getting the water to the right temperature. The more expensive machines get it there and keep it at the right temperature to not burn the beans or let them cool too much, right?
After buying expensive machines that break down every couple of years, I found this at a local coffee shop. It takes about the same amount of time but won't break down and is less than ten bucks, (not including the hot water machine that also works for tea.)
Heat the water to 200 degrees, grind the beans while it's heating and add the paper filter. Wet the filter, add the beans, then start pouring the water. The perfect cup.
I’m the same school, hand poured water and coffee filter for me is the best way to get the most pure taste.
What I’m obsessive about is to source coffee in ways to avoid contributing to the catastrophic deforestation (and contribution to global warming) caused by the culture of coffee, in particular in Brazilian plains where they grow “Robusta”. I remember reading that coffee is the second or third largest source of deforestation worldwide but can’t remember the source.
Arabica needs higher altitudes so I suspect it’s safer in that sense, but I prefer to seek out organic forest grown coffee, preferably fair traded from small growers.
That’s led me to diversify countries of origin as I used to be entirely wedded to Ethiopian coffee.
Thanks!
And I almost wholeheartedly agree, because in my opinion baskets are actually a major factor due to the difference in hole count and the sheer difference in quality between them. The good news is that even a €30 precision basket will give any setup a nice bump compared to an OEM basket so that upgrade is very accessible.
The article I linked before was written as a response to this video. It is appears clickbait-y but the contents are certainly worth 15 minutes of your time if these things are of interest to you. Long story short, I tried the shaking method and it has proven a major improvement compared to my WDT technique.
Here's my caffeination station.
I've found that the single most important factor to good espresso, assuming good equipment and basic technique, is freshly roasted beans. Doesn't matter a hoot how you treat the grinds or the puck. If your beans are more than a week past the roasting date you're out of luck.
That pretends on the bean and the level of roast. If they are roasted quite dark, they have a shorter shelf life. Some lighter roasted beans need at least a week of rest.
Agree, I think a week after roast is the sweet spot.
I have a Decent espresso machine and Kafatek Monolith Max flat burr grinder.
Obsessed!
Darn, this topic is long forgotten it seems. Allow me to bump it with my newly acquired Rocket R58.
Damm, that is sweeeeet! You brewed with it yet?
Yes, but only one cup since it's close to bedtime here 😀
Compared to my Bezzera Magica which I purchased the Rocket to upgrade from, the rotary pump opposed to vibratory pump is far quieter. There is also a distinct difference in coffee texture and taste, with the Rocket being more silky/smooth in texture and rounded off in taste, opposed to the Bezzera's always slightly murky texture and harsher taste.
This is total nitpicking of course to people who aren't coffee nerds. But it definitely is distinguishable. The girlfriend agreed 😁
Beautiful machine, enjoy 😊
I have a Bezzera BZ 10 which I am very happy with, but it’s interesting to hear of the difference the rotary pump makes, I may have to investigate that further👍
Wow that looks uptown, gotz. Game
No everyone’s cup of…errr, coffee. But I’m trying out a new cold brewer.
Will report back tomorrow.
Definitely could've cut it with a bit more water lol.
It is VERY strong. The trial (and error) continues!
That's a cool looking machine. I like me some cold brew 😀
I am pretty sure that the ratio should be similar to filter coffee. So approx. 60-70g of coffee per liter of water. Cold brew should be relatively sweet. If it is murky and bitter then perhaps your grounds are too fine.
Could be. This old grinder will make the beans powder if you're not careful. And I wasn't careful hah. Color was pretty good though.
And speaking of machines, who crafted your knobs? Those sure are pretty!
