Batavi Kosmopoliet GMT ----- ETA 2893-2
I'd actually pulled my funding before, as I wasn't too into any of those colorways and I figured I'd just sit it out. Which is good, because I do quite like the gray and it seems it's a separate product rather than just being able to choose it after the campaign, so I may back again and go with that one. I also have the Yema, but found it's a bit too nice to fill the travel watch role I bought it for so I've actually put that up for sale.
One issue I have with them though is the bezel numerals are misaligned - they're all upright, so 0800 thru 1600 will be upside down when you're viewing those timezones.... maybe something worth verifying on IG before production?
the grey looks like the winner. the vintage lume looks really goot with it. i'm a lil concerned it looks better than it should.
i just wish they had a better mock up with the dlc model. the photoshop they're using doesn't make it look that nice, but i'm sure it will be much better in real pics.
i would like to get both the black and grey....i'm surprised i don't like the green more than i do. maybe because it looks too metallic
I think I'm gonna sit this one out unless there's an update about the bezel being aligned properly - I don't think I want a watch with the numerals all facing upright.
i didn't even notice that until you said something. it does look a lil weird. they might change this if we ask them
i don't think it bothers me....the rolex explorer II has it that way..but now that u say it, it bothers me some
That's because the Explorer II doesn't have a rotating bezel though, just a 24-hour hand.
I hadn't noticed the bezel numerals until you pointed it out either, but that might have been partly because I was mostly looking at the Arabic numerals that I don't understand, haha.
does anybody know how much better the eta is over the soprod.
seems like within 10 years the soprod went from being better to not as reliable and problematic.
I think either depends on the grade of the ebauche and how much work went into it. I have a $250 micro with a 2892 keeping chronometer-grade time, and I've had TAGs with 2892s run terribly from new.
that is not an acceptable answer
I think you misunderstand.
So, a basic primer: Off-the-shelf movements are sold as what's called "ebauche" - which is the basic movement, without any customization. However, they're sold in different grades (at diffferent price points) - the ETA 2892 for instance, can be purchased in bulk as either a cheap basic movement up to a chronometer-rated, finished movement with a few grades in-between the two. Traditionally, the watch manufacturer who has bought these movements then decorates and regulates them to their own specification.
What I said with my previous statement was that asking how much better the ETA is versus the Soprod movement, has a whole lot more to do with two factors.
ONE:
What this means is that if a chronometer-grade Soprod ebauche is available in the Batavi GMT for less than the same cost as a lower-grade ETA ebauche, the watch may keep better time despite it being a "cheaper" movement.
TWO:
What this means is how much customization (essentially refinement ) Batavi is putting into the movements they source from Soprod and ETA. This includes regulation of the movements, so again, if Batavi is sourcing Soprod movements for less than their equivalent ETA counterparts and is then making up the price difference by ensuring that the movements are performing at a higher level, the Soprods may be the better option. On the other hand, if Batavi is finishing the movements with the same amount of effort regardless of where the base movement comes from, it could be the case that the ETA performs better.
ONE:
TWO:
not trying to be an ass, and i appreciate your answer. but it wasn't really what i was looking for. i was looking for a much higher level answer......not this is better becuse of xyz......i say this because not long ago soprod was on the up and up..and considered par with the 289
With responses like this and your previous, you may not try to be an ass, but you achieve it marvelously anyway.
wasn't my intention though....stuff gets lost in translation on the internetz
seems like this 2892 premium eta or whatever it is was once a grey thing. and to some extent still is. peeps that bought the steinhart gmt that contained it were going into conniptions about it a few years ago. it was being billed as a top grade when it was basically just an elabore with with a little bell and whistle for the most part, when rolled out.
as for the soprod. all the info i've seen is limited....but many said the A10 was on par or if not better than the basic 2892 not too long ago..and in some cases equally expensive, and sought after much more than the 2824..but they no longer offer the A10
i don't know what happened in the last few years but it seems to have fallen out of favor to some degree.
batavi choices are basically an an M series which prolly isn't nearly as good as the defunct A10 vs an eta 2892 elabore for +$80-100 more
if i'm reading this right, it seems like on soprods site they compare the m800 to a 2824..and the movement batavi is using is the 100 series. which is the lowest grade.
it almost seems like getting the eta is a no brainer if you buy. especially if you factor in possible potential problems with the soprod
http://soprod.com/mecanique/#classic
anyone buy?
i was about to pull the trigger on the dlc and pulled back. since this isn't a LE watch you can pick one up later for $230 more if it looks good...and since they didn't sell that many watches and have limited presence, you might even be able to get it for the same price in a holiday deal.
last time i checked i think they sold one dlc model..only to have it cancelled with the eta
anyone buy?
They cancelled the ETA version? That’s what I would have gone with if I had backed them, so guess it wouldn’t have worked out anyways.
Once @abrod520 pointed out the upside down numbers though, that was a no go for me.
i don't think the cancelled it?. i just remember seeing only one that sponsored it, and then 12hrs later zero people buying it. i'm thinking he backed out
Sorry, I misread, I thought you meant the entire ETA version of the release.
Not sure if you're only discussing one of the colorways, but there are 61 backers of the ETA movement in general on the "Super Earlybird" ETA line.
I've decided to sit out micros for now in general - like the upside-down numerals on the bezel, there's often one glaring way each model falls short and ultimately I'll stop wearing the watch as I find something a little closer to what I'm looking for. But I do look forward to seeing these if any of you did go forward!
