3861 movement broken? *Update: Read First Post*
Just picked up a 3861 speedy from Tourbillion yesterday. is this something I should worry about? So far I cannot replicate the issue. I doubt these sit on the shelf very long so hopefully it haas the updated part.
My 3861 is running fine since I got it in Aug 2019.
So picked up a new 3861 on Friday. I thought I had fully wound it sat am but maybe not. Sunday about noon I went to start the choreograph and the entire watch stopped immediatly. I stopped and started it again and let it sit on the table with the chronograph running and it completely died 5 hours later so I left it. Went to bed thinking maybe this was a power reserve issue. I reset the chronograph and started it about an hour ago and it's still running. I have not wound the watch at all and want to see how much longer it will run. Is it possible its just low on power and thats what's causing this or do I have a dud? Is it normal for a speedy to act this way with the chronograph when the power reserve is low?
Other than the initial stopping of the chronograph after you first wound it (partially or fully, not sure) and it stopped, everything else you have described would be pretty normal with a watch that is low on power.
Fully wind it, meaning wind the crown until it is impossible to wind any more, then repeat the tests and see what you get.
It has been my experience with both the 1861 and 1863 that using the chronograph in both start/stop, re-start the run, or re-set to zero, that the entire watch runs normally until the expected power reserve has been depleted. I have also used timing applications to measure the accuracy of the watch with and without chrono use and found it to be unaffected (about + 4spd) with my 1863 over seven months of ownership since new.
While I’m describing the previous movement and not your 3861, your experience does not reflect what I would expect any chronograph to do (if I understood your post correctly).
I would assume a chronograph would work perfectly until the power reserve gets very low then at that point it may run only a few more mins. The power reserve is getting low on mine and with the chronograph running the watch stops more frequently as it gets lower. The watch still runs even after this started 7-8 hours ago. I think it's getting close to dying now as its stopping more frequently.
Im going to do a full wind soon and keep an eye on it. Im just concerned if when the power reserve gets down to 10-15% left should the chronograph have this issue? I thought power reserves are consistent until it's almost dead. I.E. if im getting the full 60 hours is it possible the drag on the chronograph would causes issues like this when it has about 8-10 hours left hours left? I just want to make sure I have an issue before I try to exchange/return it.
First, I would always defer to Archer.
I understood your first post to indicate that when you activated the chrono, the watch completely stopped. Then, by stopping the chrono, the watch ran another ~ five hours without winding. If that’s accurate, it doesn’t seem as though the movement is behaving normally -but- put me in the column of “curious,” not-at-all authoritative. My watch does not behave that way.
z
Yes its like the lower the power reserve gets the more the chronograph has issue such as stopping after running a bit or right after starting. Fully wound it has no issues that ive seen.
z
Read it again...he stopped and started the chronograph, and it stopped with the chronograph on. Then when the chronograph was switched off, the watch started running again, which is exactly how I would expect it to act.
The lower the power reserve gets the more it stops. Its still not depleted. so Id say this started happening with at least 10 hours left out of the 50. I don't think thats right. It's like the lower the power reserve the more the chronograph drag can stop the movment. I would not have wanted this on Apollo 11 lol. I don't know if I should swap or ask for another. Seems too common.
Got it.
Al, would you expect the 1861 to behave in the same way (maybe I’ve not experienced this exact point in the power cycle - now even more curious..)?
z
Thats what im trying to determine. It's my first manual wind. Id assume with a 50 hour power reserve this would happen in the last hour or then die. vs still running another 10 hours and getting worse and worse. I don't want to waste my time exchanging it if this is the way the 3861 behaves. But then its hard to accept a watch that only performs properly fully wound vs 25% power reserve etc. Movement has been out 2 years I would think they would have gotten most if the bugs ironed out.
I guess my question to Archer is what is considered low power? 15 hours left, 10, 1 etc. When should the behaviors I described manifest in a manual wind speedy.
I'll start by just saying there's still doubt that this was actually fully wound based on your post above, so I am assuming it wasn't, because this is your first manual wind, and there are countless threads with people asking how to tell if the watch is fully wound or not. This is why I suggested making sure it was fully wound and then doing the test again. This really needs to be done in order to give you any kind of solid answer, and anything before doing that is just speculation. I know on WUS people are telling you to immediately return it, but in my view there's not been confirmation that there is even an issue yet.
Now onto a more theoretical discussion...
I'm not really sure what "getting worse and worse" means here, but let me explain how this system works, because the questions being asked indicate that some are thinking of this in the wrong way.
People tend to think of the power in a watch like fuel in the tank in your car. The harder you drive the car, the greater the fuel consumption is, so the "faster" it runs out of reserve. This is false.
The power reserve of the watch is a built into the design of the watch, and is a simple calculation based on the length of the mainspring, number of turns of the mainspring barrel, and the ratio of gearing. The power reserve is designed into the watch from the start, and does not change based on running the chronograph or not.
In a watch the mainspring puts out a certain level of torque as it winds down, and that torque will drop off as the end of the reserve is close, and that is one side of the energy equation. The other side is the load on the movement, so think of the watch running when the chronograph is stopped, the load is just what is required to make the watch tick and drive the constant second, hour, and minute hands. When the chronograph is started, that adds the load of all the chronograph parts to the watch, but the spring still only delivers the same torque.
There is a point that is reached when the watch runs long enough, that the torque being delivered by the spring drops off to a point where it can no longer keep the watch running, even though there is still wind left in the mainspring. The point will vary depending on the load side of the equation, so if the watch is running with the chronograph on, then the point at which it stops will happen sooner than with the chronograph off. So if you wind the watch and let it run down with the chronograph running, it will stop, but as soon as you turn the chronograph off, the extra load is removed, and this is enough to get it running again.
So if any of you want to prove this, fully wind your chronograph, set the time, and lay it dial up and let it run down. Note how long it runs and this is test 1.
For test 2, repeat the same thing but this time turn the chronograph on, let it run down until it stops, and note how long it runs. Then turn the chronograph off, which will start the watch ticking, and without winding it again, let it run down and note how many hours it runs. Add the time with the chronograph on to the chronograph off in this test, and it should equal the time it ran for the whole time the chronograph was off in test 1.
This will be true no matter if the chronograph is an 1861 or 3861.
There have been many previous threads on this, so if you search I think some people did this test and posted their results. This was before the 3861, so I don't know how many hours would be "normal" for the 3861 to run once it has run down enough to stop with the chronograph on, and then you switch it off. I do recall people talking about 4 or maybe 6 hours more run time on an 1861.
Hope this helps.
Worse and worse means when I run the chronograph the watch stops more frequently. So far its stopped about 5-6 times. I have not wound the watch since this started and its still been running for almost 15 hours now after the first incident . its a 50 hour power reserve should this issue pop up when there is still 10-15 hours left? Its still running perfectly unless I use the chronograph then it stops frequently.
Long story short, this watch needs to be fully wound to work properly. If itsgot 25% power reserve there will be issues running the chronograph where the entire watch may stop. this doesn't seem right. If it only had an hour or so left I would expect this behavior.
Thanks
Hope this helps.
Total answer - perfect.
Thanks as always-
z
Have a an Apollo 11 still in it's plastic and you are making me think, I need to star wearing it, just to check the issue.
Just did a full wind until I can no longer turn the crown. Started the chronograph. I'll see how things go in the next 50 hours and report back. Once it gets down to about 50 percent and 25 etc ill start and stop the chronograph several times and see if the watch locks up again. Thanks for everyones advice and to Archer. These things are not cheap but we love them. I got perfect copy otherwise and don't want to exchange if its fine.
Well...
And...
Let us know what happens...
