3861 movement broken? *Update: Read First Post*
Do we know for sure if there is any correlation with the serial numbers being in order by date of manufacture? The one I returned a month ago due to the issue was 824*****, My AD got a couple in one is 829***** and one 834*****. I'm thinking to have him run the 834 with the chronograph running for 50 hours to see if it stops. I really like this watch and want to buy it back but id like to be "pretty certain" it has the upgraded bushing etc. Thanks
I just got three new sapphire sandwich 3861s directly from Swatch Group in New Jersey, shipped on Monday. One 824****, one 829****, one 834****.
Interesting. That’s similar to what my AD got. Wonder if it means anything.
So what would be a fair power reserve with it turned on to conclude the watch probably has the upgraded parts? The one my AD tested got 54 with it on non stop. I got around 30 on the one I returned.
Impossible to answer, just having a certain run period length doesn't tell you anything. My two year old 3861 ran for 57.5 hr with the chrono on before it stopped, but this doesn't tell us anything. It's just a crap shoot right now whether any 3861 is going to have a problem or not.
Well picked up a brand new one with829 as the first 3 in the serial. Did a full wind until it stopped before a left the store. 20 hours later I was able to replicate it twice when starting the chronograph. At this point I don’t think current production is fixed. The more you look for it the more likely it will happen. Seems to be more common about 20-30 hours into the power reserve so those that fully wind every day may not notice it. Maybe I should just forget about it and just enjoy the watch and maybe send it in a year down the road when omega truly has a grip on it. They said I can swap again but The 2 they have are the same serial so I’m pretty sure it will pop up there.
So far, I haven't seen this problem manifesting itself in the Apollo 11 50th Anniversary editions. I believe most, if not all, of these watches were made in 2019. Was there some slight difference in the materials, design or assembly of the Apollo 11 versions? Mine ran for nearly 50 hours with chrono running and didn't show any stoppages.
If you read my first post on this thread, mine was an Apollo 11 steel/gold. The first known issue in here was the gold version as well.
I’m not sure it’s leaving the chrono on that’s the issue. More repeated on/off - at least that’s what I believe gave mine the issue (but I’m not an expert).
The OP' watch was an A11 50SS, the standard 3861 models were introduced at the start of 2021. Seems to me the issue could only first have manifested in A11's as @Archer posted about weak balance amplitude in this thread in september 2020.
The chronograph really has nothing to do with the primary issue. The real issue is the bushings in the movement that create debris and wear on the center wheel. This lowers the balance amplitude, and when the added load of the chronograph is put on top of that, the watch will stop when this gets bad enough.
The chronograph is just the extra load that trips this problem into showing up, but is not the cause.
It seems something similar to Rolex 32xx issue.
The last one would sometimes stop when starting the chronograph. This one started doing it after 20 hours into the fully wound power reserve. I’m going to leave the chronograph running and see how long it runs before it stops. The last one would die between 24-35 hours into the power reserve.
.... Did a full wind until it stopped before a left the store. 20 hours later I was able to replicate it twice when starting the chronograph. ...
.. Maybe I should just forget about it and just enjoy the watch and maybe send it in a year down the road ...
Can you really enjoy the watch that is functioning that way?
Yes, makes sense. If it’s the load of the chronograph which makes the watch stop, then it makes sense that people are seeing these issues if they use the chrono more regularly than others.
as you’ve said earlier, a non chrono user may never notice the issue and in any case it will be dealt with at service time anyway.
Knowing that there is a fix and that winding it every day is the workaround for now I can esp since I have others to cover me when and if I send this off. I’d rather have this issue then the Rolex 32xx issue that has no resolution. Honestly if I exchange for a third it most likely will have the issue but now I don’t have to wonder if it will happen with this one. Who knows the 3rd might even be worse.
just picked up a zenith chronomaster sport last week and it did freeze up once when starting the chronograph fully wound. I can’t replicate it again. My guess is being a lateral clutch the 2 teeth hit at the end points which is rare.
But, what if someone keeps on using the watch when there's a bushing that needs to be replaced and oil added, are you damaging more parts of the movement without realizing that you are in fact doing so?
No. And even if you were, it will all be covered at the time of service.
If this is wearing with the bushing why is it happening with so many right out of the box brand new?
Yes, except we know that Omega has an answer for this one.
For those who have not heard about this issue....
So, they purchase a new watch without realizing that, what they have just bought has to be sent back for repair, hopefully returned back to you before the end of this year. Not good!
So sorry but I stand by what I have said. They should have called in all watches back from the OB's and AD's.
The way I see it, things have gotten out of hand by now!
Because watches are run before they ever get to the store, as I've said already.
Stay angry!
