1940s Omega pickup
Since it didn't match the watch in terms of size, there's little doubt it waasn't the original. It wouldn't concern me. It may not have come with an Omega-branded strap, either. I would look for a nice 11/16ths pigskin as this watch may predate metric straps.
The watch in my avatar is 11/16ths, for example.
Thank you for the message and advice! 馃榾
I鈥檓 on the hunt for a simple strap for this watch like you said, as it is fixed bars I鈥檓 a little more limited on choice. The only one that fitted it from my box of straps was this leather nato, but I鈥檓 not too much of a fan of these because they make the watch much more chunky. Still it doesn鈥檛 look bad.
I am chatting to a gent that can make me some that will fit in leathers like these - but open ended.
I鈥檓 thinking of going with one of the ones I鈥檝e circled in red which are apparently goat skin but it鈥檚 such a hard decision when you can鈥檛 try them on your watches first...
Your watch in your avatar is a beauty - and quite similar to this one of mine, does yours have fixed lugs too? 馃榾
Thanks again,
Ollie 馃榾
Should I just bin it?
Yes. 馃榾 Straps are wear items with a limited lifetime, and yours is too far gone to save. You'll want a fresh new strap without any DNA from the previous owner.
However, some of us OCD collectors 馃槜 like to have a strap that matches the era of the watch and will use the old strap as a model for what a new strap should look like. If you go with a bespoke strap maker, give them your old strap so that they can match the style of the stitching, the thickness of the leather, and the single keeper.
Great idea! I didn鈥檛 think of that 馃榾
The goatskins ones you show are definitely in keeping with the style of the period- particularly the third one down that you circled. Care to share the maker?
Before having anything bespoke made, I would carefully check your lug width if I were the OP. The 13322 in my experience has a 18mm lug width. If yours is the same, a 11/16" strap may be a little loose as it is half a mm narrower. Likewise a 18mm strap may be too snug if yours is 11/16" between the lugs. Imperial lug measurements were often seen on US domestic cases, less so UK domestic like Dennison which is a little strange I know.
I agree with JWR on all fronts concerning the red circled straps, including being interested in the maker. Lovely looking pigskin strap that.
No, it's a different reference.
And, since it has fixed bars, you do indeed need to measure, I didn't see that in your original post.
I think I鈥檒l be going ahead with that one. When I next speak to the maker I鈥檒l ask him if it鈥檚 okay to share his details and revert.
That looks nice! I have similar hands in another watch, but mine haven't aged so well.
I'm too lame to figure it out - what's the case diameter and what caliber sits in there? Is it cal.30(T2?)? 35mm-ish case?
I measured the case and as suggested before it is 33.5mm, wears quite nicely on the wrist. It鈥檚 an ideal size for my wrists for a slim watch with a somewhat thin bezel.
Btw...How much you have to pay ?馃槈
I picked it up for 拢500, what is the consensus on value? Is that about right? Or was that a good buy, or too dear?
Interestingly this Dennison 13322 case has fixed strap bars, often a sign of military heritage. This case was used to re-case some military watches post WW2 and is sometimes seen with the dial/hands layout of the Omega 6B/159, also the wonderful Longines COSD. Obviously, the vast majority was used for many civilian watches too although I don't recognise this as a former military watch. I think that Dennison produced 10,000 of these 13322 cases in stainless steel and a small amount with a plated mid case.
Fabulous watch, congratulations.
Do you think that an owner at some point may have soldered them fixed? Or do you think it is original? Also I haven鈥檛 seen this dial before on a watch with this case the closest I can see is some of the Swedish Suveran watches. Could it be that there were watches in the UK with very similar characteristics as those Swedish examples just cased by denisson instead?
The fixed lugs I am sure are original, the mid case has the 4 digits from inside the case back near the 1 o'clock lug, this is a characteristic of fixed lugs I think, they only have the last 3 digits if they have spring bars. The same numbers, 2697 will probably appear on the bezel too as it is a 3 part case.
Regarding the dial I don't think I can add anything of value but Omega used Dennison cases on a wide variety of watches in the UK. There are 2 types of case back for the 13322, a higher, raised one for the centre seconds and a flatter one for the sub seconds watches.
I think that 拢500 was about the right price for such a charming watch with it's case. I agree too, they wear really nicely, good proportions. I have one with a Smiths movement in it.
love the lime on the dial and hands - its still radium or?
Yes all of the numbers match on the mid case and bezel 馃榾 that was one of the first things I checked.
It鈥檚 from 1944 so I should imagine it is radium lume.
