1479 bracelet sizing and compatibility question
Long time lurker asking for help.
I'm looking to buy a early 90's 1479 (812 end links) bracelet for my speedy 145 022 71
I've searched the forums but can't find the specific answers to my questions
1) will the 812 solid end links fit my case? I know that the 1479 came originally on the 145.022 models so technically it should be the same as my 145 022 - 71. But I've read a few threads where it seems omega made subtle changes to the case designs and lug hole placement over that years. I was hoping that another OF member has tried this and can confirm compatibility?
2) I have 16cm (6.25inch) wrists. I wear the speedy quite well as they are quite flat. But does anyone who has the 1479 on their speedy know if there's sufficient adjustability in the bracelet (removable links and clasp anchoring points) to get a good fit on my sized wrist? I don't have a problem with the modern bracelets as they have enough adjustment but I'm conscious the older style bracelet weren't always designed to be as 'accommodating'
Thanks to forum member Ti22 who's indicated that the end links should fit.
Should be good, the clasp have 6 points for adjusting.
