105.003-64 Speedy. Help please
  • I am concidering buying this watch. May someone be able to help me?
    Its a 105.003-64 without bezel. The watch has a 321 movement with 25xxxxxxx serial (seems to be 67??)
    Thanks in advance.
Edited by a mod:
Help us help you... any more info you've got? What's the asking price? I mean.. if it's like 1 dollar then you should buy it without asking here. Some things come into mind when looking at this, but it's all really dependent on price.
its -depending to other adverts- a fair price. For sure, a DON bezel will be around 2k and a flat link bracelets maybe another 1,5k but the watch itself looks interesting. I have been searching quite a while to find such a NCG Speedmaster. The dial looks legit to me and hands as well, but I am worried about the case and movement correspondance, regarding the serial.
Thanks in advance.
Do you have any more photos? Chrono hand is wrong, in fact hands likely replaced.
Hands wrong
crown wrong
Case seems quite polished
Dial isn’t attractive
Bezel missing.
Obviously the above is based on one poor photo. Additional photos and price would hep
"Hands wrong
crown wrong
Bezel missing".
Furthermore:
Band and end links missing.
(note: correct band with the right date stamp and correct end links, very hard to find and expensive...)
Abstract from the archive missing
Is the crystal a A1 type?
But, anyway, if the price is right and you like it, go for it.
Cheers
"Hands wrong
crown wrong
Bezel missing".
Furthermore:
Cheers
Well let’s be fair, when assessing a watch head, you don’t mark it down due to the absence of a bracelet or extract. Of course they impact the overall package and value but are separate elements to consider.
thank you for your responds. May I ask if it is normal, that the serial of the movement pops up to be a 67?
Furthermore, is just the big second hand replace or all 6?
Thanks
Thank you guys. I know the issues about the bezel and the bracelet and its around 3-4k to spend... But I am unsure about the movement situation.
Have you checked the serial against MWO or Speedmaster101?
I can check MWO later.
MWO - Moonwatch Only. Speedmaster bible but it’s a book so you can’t check it if you don’t have it.
SPeedmaster101 is a website which you can check to give you an idea.
Okay, the MWO i dont own. But the serial is definitely not matching. The speedmaster101 is signing this... But i though this already.
The abstract would clear if the movement would be ok for the watch.
IMHO
IMHO
The extract will only show the reference, not sub reference. So it will show 105.003, not 105.003-64 etc.
Re the serial, it’s not within range for a -64. MWO has a -64 as 20.5m to 22.8m.
The abstract shows if the movement was used on a Speedmaster or not, furthermore if the movement would
not be correct for a 105.003 whatever year they wouldn't even answe, keeping the money...
