Received a Strapcode Endmill bracelet for Turtles. Trying it out on the Save The Ocean and having fun comparing with the Strapcode Jubilee on PADI.
The Endmill links are quite a bit longer than the Jubilee (non-angus) in the 12 to 6 o'clock direction, 8mm vs 6.3mm.
Both taper from 22 to 18mm, which I like. The oem bracelet does not taper.
I'm so used to the STO on the oem black rubber by now that this is taking me a while to adjust to.
Clearly, I now need more Turtles! 😁
Phlieger Phriday with a generic ETA 6497-1 built at AWCI Build A Watch school...
Like many of us I have some downtime around the house. To fill the time I decided to do some household desk-diving and afterwards I'll lighten up the situation by opening the helium release valve. Whooeee! Some fun!
Just for fun Speedmaster. I had an old MkII case which had been attacked with a wire brush by the previous owner and was in a very sad state, so decided to 'refinish' it and use it as base for a Silver Machine Speedmaster. Went for a radial finish as no way could I do a correct sunburst finish, and refitted the original crystal with the black paint removed. 😁😁😁
That looks great!!!
Had bicep repair surgery Tuesday so nothing for the next couple of weeks unfortunately
Wishing you a quick and full recovery. You have another wrist, right?😉
Perfect time to use/get yourself a replica long velcro NASA strap!
