Watches gaining time when walking
For a watch to “bank” because of a problem with a gripping bridle, the amplitude of the balance wheel would have to be closer to 650° Or more for the roller jewel to strike the pallet horns on the outer surface. The one quote in the link indicated it would bank at about 360°. Not possible.
I suspect that the OP in that link made a mistake when he said 360°. Question, though - if it was banking, but only when the mainspring was fully wound and the oscillalting weight was applying further energy, would the amplitude be likely to be abnormally high in other situations too?
This sounds like it might be the same problem. Although if so, the watchmaker must have made a similar mistake when servicing both movements:
https://www.thewatchforum.co.uk/ind...-m177s-gain-time-while-i-was-walking-the-dog/
Yes, rebanking is the most likely cause.
One way to test this is to let the watch run down for 24 hours before taking it for the walk. If the gain doesn’t happen, you know that it’s rebanking.
If you have a timing machine this can be checked by fully winding the watch, placing it dial down on the machine, then use something to slowly turn the rotor, and watch for the amplitude to spike.
I suspect the timing machine would pick up the sound of the rotor being manipulated, thereby giving an unreliable result.
You suspect incorrectly. The rotor noise isn’t a factor, because it’s turning very slowly. This is a test learned at watchmaking school...
You can even tell when the bridle slips if you do the test correctly...
I'm waiting for both watches to wind down, and then I'll take each of them for walkies...
How much should I wind them to get them going first? I guess you wouldn't want no wind at all in the mainspring, as that in itself could cause inaccuracy?
How about if I give five winds of the crown to get the watch going and then immediately go for a walk? Or just one or two winds, or ten?
Incidentally, I've thought about getting a timing machine just for fun to compare all of my watches and encourage me to learn more about them. What would be a good basic model to go for, and where's the best place to buy them? I'm in th UK but it's weirdly difficult to find any for sale locally, they all seem to ship from China (which is fine, except I hate waiting for stuff.. 😉
These don't take many winds of the crown to be fully wound, so maybe 3 or 4 is plenty.
So... I took one of the watches for a walk yesterday morning after letting it run down (I gave it 4 winds to start it up). It kept perfect time.
However.. after wearing the watch for the rest of yesterday and for a few hours today I went out again, expecting to see it gaining time again in the fully-wound state while walking. But after 40 mins of walking it was still spot-on. I then gave it 40 winds of the crown just to make sure it was fully wound and kept walking for another 20 mins or so, but it stubbornly remained accurate to the second!
So now I am just mystified.
I think you are very much incorrect here. Could you elaborate on what you mean?
It's still very possible that it's rebanking. To determine definitively you would need to check the amplitude on a timing machine, as has been mentioned previously. It's possible that it won't rebank on every occasion. Any watchmaker will be able to check it on a timing machine for you.
Is there a difference between "rebanking" and "overbanking"?
Yes, overbanking is when the impulse pin ends up stuck on the back side of the pallet fork horn.
Rebanking, or knocking, is when the impulse pin touches the back of the horn and then comes back around. Basically, the balance has travelled too far.
Yes, overtaking is when the impulse pin ends up stuck on the back side of the pallet fork horn.
Thanks. I have a 2" Ansonia clock movement that some "repair person" (dipstick) put way too strong of a mainspring in so I want to use the right term when I bring it to the clockmaker.
Simple way to remember
- Overbanking: watch not running
- Rebanking: watch gaining time
Just wondering: is there a typical amplitude range that alerts one to the possibility of re-banking?
It does depend on the movement. Some caliber’s have lower amplitude upper limits than others. If you are seeing 320-330 degrees at full wind you have a very high chance of rebanking, if it’s an automatic watch. It also depends on the efficiency of the automatic winding system being used. There was talk in a previous post about rebanking being impossible at 360 degrees. Really don’t know what that is about. If a watch balance has amplitude of 360 degrees it’s rebanking.
Omega state that amplitude shouldn’t be above 315 for an automatic watch in the dial up position and 325 for a manual wind watch.
Again, movement specific. A rolex 1530/1570 has an upper amplitude limit of 280 degrees.
Personally, I think 280-300 in the dial up is around the right spot.
What I find curious is that high amplitudes occur in the horizontal positions (dial-up, dial down). These are not the positions that occur when walking. Significant re-banking in vertical positions appears unlikely to me.
It does depend on the movement. Come caliber’s have lower amplitude upper limits than others. If you are seeing 320-330 degrees at full wind you have a very high chance of rebanking, if it’s an automatic watch. It also depends on the efficiency of the automatic winding system being used. There was talk in a previous post about rebanking being impossible at 360 degrees. Really don’t know what that is about. If a watch balance has amplitude of 360 degrees it’s rebanking.
Excellent, many thanks.
In a static situation, you would be right. This isn't static...
