Turning lemons into lemonade
With the exception of the beautiful wood and the table it is made from, not a happy story from my POV. Cutting down trees, turning cottages into mansions, replacing privacy with density...all sad stories about the last 70 years. The neighborhood I grew up in was made up of varying size homes, lived in by diverse families with different incomes. All of us kids played together, a neighborhood band of brothers. And every neighbor knew the names of all the children. Many a night one of my friends would eat at our dinner table or I'd be eating at theirs. The trees that were cut down are part of a vanishing landscape with different values.
You could also use some all while keeping the bark to make a new headboard for your bed, with a matching bench in your bed room,
- a fabulous and stylish new kitchen counter (pictures below)
- a fabulous and stylish bookshelf in the same vein as the architectural project below, it does require high ceilings and an otherwise very pure/ uncluttered room IMHO. Question whethet those slabs would be too thick?
- do a long bench in a foyer with shoe storage underneath,
Finally maybe you could also create a sauna cabin using those slabs as architectural elements.
Thanks for all the suggestions in this thread and by PM. A wide range of options, from knife handles, giving some to a luthier, shelves, tables, and even wood chips...that last one is off the table, no pun intended.
We already have plans for a large table, plus some smaller tables. As well, we want to use some of the nicer live edge parts for some floating shelves. We already have a solid maple bed, but the idea of using this wood to make a new bed frame and headboard is an intriguing idea...
We have granite countertops in our kitchen, and with the amount of cooking we do, wood just wouldn't stand up. However we have a small "telephone table" with a granite top that I have already talked about removing, and using this wood for.
We have also considered using a slab as a wall hanging...in the solarium area where the table will go, we have a very tall wall that is tough to fill with anything, so a long slab hanging vertically might just be the trick.
I'm sure we will find a use for most of this, and we also may talk to the saw mill about then buying anything that is left over, to help compensate for what all this work is going to cost.
Ever since these trees came down, I have been looking at table designs, leg designs, and have watched a ton of table builds for ideas on YouTube. One channel I like a lot is Black Tail Studios...here's an example of his work:
Interestingly enough, the tables he makes are not how he makes his living, it's from sponsors for his videos... ::facepalm1::
The good thing (I guess) is that we have time to think of things to do with all the wood. 👍
I just texted pictures to a couple of architects I know in North America, one of them says those slabs are beautiful-
She suggests reaching out to Room and Board, they’re a furniture company based in Minnesota that focuses on sustainability and American craftsmanship. She says worth reaching out to them directly.
Thanks - shipping across the border to the US, some 1300 kms away, is probably not in the cars, but I appreciate you doing that.
Let me know if you want a knife with the handle made from your tree @Archer
Mates rates and you won’t be charged for the handle material 😉
I only need a few small blocks 😗
We will talk...👍
That’s just horrible. Trees (and all other non-human life) is precious…they are the lungs of our planet. I truly wished people cared more for trees and nature. But that’s a can best left closed. Lemonade…yes…but lemon meringue pie…now that’s something to aim for : perhaps you folks can try and offset the loss of trees by planting the same amount of new ones…just a thought.
In many larger cities here, there are bylaws regarding tree removal, and often requirements that if you cut one down, you need to plant a replacement. We live in a rural municipality and no such bylaws exist here. This is something that I will be pushing for personally, at least in settlement areas.
In Ontario, we have something known as conservation authorities - we are the only province to have these in Canada. These 36 entities are responsible for managing various watersheds in Ontario, and ensure conservation of land, water, and natural habitats across the roughly 1.1 million square kms of the province (Ontario is a big place - much larger than Texas for example, and 4 times the size of the UK). They do have a say where there are endangered species, waterways, or large volumes of trees are at risk. They did review the entire subdivision plan, as these things have to go through many approvals - environmental assessments, archeological surveys, etc. This particular stand of trees was not large enough or special enough to warrant their intervention - we did ask!
As noted, we have already planted around 30 trees since these were removed, and do intend to plant more. I don't know that we can replace all that were removed in the available room we have, but we will plant as many as possible. We might not get to enjoy most of them, but maybe the next generation will.
Sounds like you are getting the pie 😀 I just happen to have a piece for you…it won’t make the trip…so I had it for and thinking of you…
Fireplace mantel, maybe. Although you might have wanted to keep a thicker slab.
How about a pipe organ? (Or calliope?)
I made the fronts of the pipes on the crank organ out of a brance from one of our montery pines. I have other logs sitting in my workshop wating to get milled. I also made a new case and piples for the calliope (known as a Wurlitzer Caliola) this photo is from before I painted it. I actually repurposed old church organ pipes for that one. Milling down the old wood.
With the climate change, We may have to let our old redwood go. Will be a sad day. At the edge of the habitat. Fewer foggy days, although the mornings have been overcast. Also have been building retaining walls. (which I should be working on at the moment.)
Dug up one of my brother's toy trucks. It can bee seen from the old post how much the hill has shifted in the 50 years we have been here. The house was built in 1943. Which makes for interesting maintenance. As after 80 years the house is an inch out of plumb. (I thought it might have silver electrical wire, but the scraps seem more like plated copper, the ends do tend to oxidize black, Not unlike what the old watch plates discolor to.)
Also reminds me I need to pick up the lemons, that have fallen.
-j
Clicked on this thread thinking it was going to be about making traditional lemonade, what a load of bleeding tree huggers .
But glad I did , best thread I’ve read for a while .
We are also looking at making some small tables for family members, charcuterie boards for people, etc.
I’ll send you my address! 😉
I agree wholeheartedly but the point was making the best out of a less than desirable situation. I think that Al comes out with flying colours. This thread yields quite a bit of lemonade!
Here’s more lemonade from my very good friend and luthier extraordinaire, Mario Beauregard…spruce, maple and ebony.
lemons lying on the ground. I should probably pick them up.
Oooo, so pretty…I kind of want to lick it. Looks like a wooden Creamsicle.
A famous Canadian wrote a song long ago… Big Yellow Taxi. Now you’ll all have that ear worm. I feel for you and your wife Al. I’d be crying too. Use that wood well.
