Tritium lume doesn’t light up under UV
And just to add to the emphasis on the importance of the phosphor decay/degradation as a factor in decreasing lume glow. Radium 226 has a half-life of approximately 1600 years (though it's alpha decay throughout pretty much all of its decay chain, rather than the beta decay of tritium), so any radium lumed watch is still pumping out pretty much the same strength of radiation as it originally had. It's the phospor that's no longer active.
And, since we're getting all science-y around here, I would expect this is partially because the alpha particles that radium emits on decay are much heavier and more destructive than the electrons (beta radiation) that tritium does. An alpha particle is a helium nucleus: two protons and two neutrons, and when it's kicked off from the radium nucleus it has about 1000 times as much kinetic energy and 7000 times the mass as the single electron of tritium decay and its charge makes it more ionizing. I don't know enough chemistry, but it's my guess that this is much more destructive for nearby substances (phosphor paint) and leads to the effect that years of radium decay can have on watch dials, etc.
Know that neither alpha nor beta radiation can escape directly from the watch itself: alpha particles can't make it through a sheet of paper, and only about 3.7 cm through air; and the low energy of tritium beta particles (5 kEv) means they can only penetrate through a few mm of air, and also can't make it through a watch crystal. Note, however, that the radon product of radium decay is a gas which can escape from a watch, and which is dangerous to human health, although the amounts emitted by a radium watch collection shouldn't be high-risk, particularly if not concentrated. Also, radium decay (and the further decay of radium products) emit gamma rays (high-energy light) which may make it out of a watch and which can penetrate and cause injury. (But again, I don't think a radium watch is very dangerous as long as it is contained and undisturbed.) There's further information on Wikipedia.
There's only one type of tritium; it's just hydrogen with two neutrons (the most common hydrogen isotope has no neutrons, deuterium has one, and tritium has two), the word is from the Greek tritos ‘third.’ because it's the third isotope and/or because it has an atomic weight of about 3 (3.016). So there's no variation in tritium, and because it's chemically identical to hydrogen, you can incorporate tritium into any chemical compound which has hydrogen in it: water, polymers, whatever, or you can keep it as hydrogen gas. Tritium has a half-life of 12.3 years: every 12.3 years, there's a 50/50 chance any particular atom of tritium will spontaneous convert itself into an atom of helium, releasing an electron at the same time. The electron hits a phosphor and excites an electron in that phosphor to a higher energy state; when it collapses back to a stable energy state, it emits a photon of light, with the color of the light depending on the gap between the two states. There are different phosphors in use, including zinc sulfide and strontium aluminate; these molecules are put into a matrix with other elements (the activator) which affect the quantum states available and change the color of light emitted, etc. Then these materials will be made into a paint by mixing them with binders, etc.
While electrons from tritium decay activate the phosphors in the paint in the usual use case, they can also be activated with UV, and because it can take a measurable period of time before the phosphor electrons collapse and emit light, there's an opportunity to see the phosphors glow after they've been exposed to UV.
So the tritium is the same and there's a pretty limited number of the phosphors at the core of the phosphorescence. What does vary is the impurities used with the phosphor to tune the color and persistence of the light, the binders, etc. This is what causes the lifespan and quality of various tritium paints to vary. They will also respond to UV in different ways depending on the wavelength of the UV, etc. I agree with @Canuck that the failure to glow may be because of the short-wave vs. long-wave illumination difference.
Nothing can be done to change the rate of tritium's decay, it's fundamental physics. The phosphor and paint may degrade at different rates depending on its formulation.
Awesome explanation !! Thanks
now that we understand tritium better, I still see some wakmann triple date out there with the markers still looking white. For a watch this age, would the tritium be stil white ?
Finally a great explanation of why so many watches have helium escape valves! ::stirthepot::
ROFL GALORE! That one made my day!
( But I hope you actually know that the escape valve has the purpose to keep the watch in balance 😀 )
I heard there are some Tritium Rolex watches that don't glow, since they used another chemical ingredients than zinc sulfide. Maybe its the case here too. I never had a non glowing Tritium watch either. In differ to that, not all my Radium watches react to UV.
Nico
I know this is an old post, but just accidentally stumbled across it. So if anyone reads it then maybe it helps. Rolex indeed used a chemical lume combination on Tritium dials beginning in the late 1960s (they experimented a lot, and this can be seen on Explorer 1016 matte dials from 1966/67 that had different degrees of “puffy lume” that made the numbers look cartoonish). Once they figured it out it became known as “dead lume” because it no longer glows at all under UV light. As someone else pointed out, it’s the chemicals blended with the Tritium that cause the brief UV glow and not the Tritium itself. If it was the Tritium, then no watch would react to the UV test as all Tritium on watches is no longer radioactive. Radium is a slightly different story as the half life is over 1000 years, but it still comes down to the chemicals mixed with it. Many watches stopped glowing entirely after about 5 years in the early days of Radium lume as they hadn’t figured out that the radon gas was breaking down the phosphorescent material. All of that said, I am only aware of Rolex using “dead lume”. I have a bunch of pre-1997 Omegas that all still glow under UV for a second or two. My Tag Heuers from the 80s glow even more. My 1963 Rolex still glows, but my 1967 Rolex does not. Not only is it “dead lume” but also happens to be one of the Explorers mentioned above. In my opinion there is no reason in theory that other companies didn’t also experiment with lume combinations, and it’s also possible that Rolex was selling compound to other manufacturers. Times were hard and this stuff happened. Finally, as many of you will notice, re-luming will probably still glow. My Explorer has a re-lumed minute hand that glows bright under UV. It may have been 90s Luminova, but due to the patina I believe it was a Tritium re-lume done some time in the 80s and not by Rolex. Once again I hope this helps anyone out there…😀
