Phranz
·Dear Sirs!
Here some seller pics of a rather beaten up Tri Compax, that I found today. I will have a look at this very patinated one in flesh the day after tomorrow.
But till then I would kindly ask you scientific researchers and horological detectives, what you think about it?
I „think“, it is within the range of being correct, in spite of some extravagancies?
I have studied in Sala about it, but these variations and details in configuration are tricky, as I have learned again and again here.
It is a S/GP ref 42406
ser.nr. 1.131xxx
cal 287 / mvm nr. 246201
seller says with crown 39mm
Sala has the same ref on p.362, but looking pretty much different. Some other configrations look almost completely alike, but have different case materials, different range of ser. numbers, different tachy scales, and so on and on…..)
The best match is on p.348, almost identical, very close ser.nr., same ref, same s/gp case, same cal 287,
……but is black, and has e.g. at the 30min register 10-20-30, whereas the object of my longing has a segmentation of 3-6-9-12-15-18-21-24-27-30. I really love that sequence and find it incredible amazing. Now this 3min intervals are to be found on others, but then other details do not match completely…
Yes, UG was in creativity and aesthetics always top!
Now please, dear Sirs, do not disapoint me with this one 😀
I am hoping and fearing at the same time, cause I like the patina, do basically not like goldplated, but this one I could afford for probably about 2k EUR
My Uni Compax should not stay alone any longer?
thx for your attention!
_phranz
ser.nr. 1.131xxx
_phranz
