For 3000 EUR I would like original lume. What is the back of the case like?
For 3000 EUR I would want a 105.012. This is overpriced.
IMHO, ..., Value will always be based
on condition. Right now, Speedmaster Tropcial are undervalued.
IMHO, if you enjoy them, Tropical dials are very collectible.
2 types, UV affected and Manufacturing defects in known serial
ranges. Both are highly desirable. Value will always be based
Take for example the Rolex 1680 Red produced in 1969 with a
serial in 2.2-2.3 million. These watches can command a premium
of 100% over a Rolex 1680 Red with the same meters first dial
that does not have the defect(and is black), and is in a 2.1 or 2.4 serial range.
For UV affected, the more symmetrical the brown toning, and
the better the overall condition, the higher the value.
But in both cases, they must be obviously Brown, or the
Tropical collector just keeps looking for the obviously brown one.
1969 was a very good year for Tropical dials. Coincidence?
relume?
Can anyone who thinks this is a relume add why, or what the tells are indicating a relume? I'm asking because I've seen several speedies (and specifically, 145.012-67's with this color lume, and, with slight puffiness to the lume, and with the lume markers appearing to be *slightly* hand-applied.
The puffiness of the -67 markers I've seen in this picture (and in several other examples) is consistent with the texture and puffing and tone known to be seen on Submariner lume from this period, as is the behavior of the lume: if you hold it to a strong light, it will glow briefly when viewed in very dark conditions immediately thereafter.
http://www.rolexforums.com/showthread.php?t=123465
Also, if you look at the geometry of the lume painted onto this NASA 105.012-66 that was worn by Gene Cernan on the moon:
http://airandspace.si.edu/collections/artifact.cfm?object=nasm_A19771179000
you'll see that while the color of the lume is very different, the geometry, including some white "gaps" of the plots showing underneath the lume are very consistent with the geometry of the 145.012-67 subject in this thread. And we know that this watch wasn't subject to a bad relume from a shady eBay seller; after going to the moon, it went to the Smithsonian.
So what we're left with is the color on the -67 being different from Cernan's watch (but similar to two other examples of 145.012-67s I've seen). . .and for that matter, some of the Seamaster 300s from -67 whose lume ages to this color), and, it is well established in both the Omega field, and in the Rolex thread referenced above, that tritium paints seemed to vary widely from the mid-60s to the mid-70s, and beyond, and that can be what we're seeing here. I'm guessing the reason for the variance is that a big lot was mixed by the manufacturer each year, which was then distributed to the few suppliers who built (and lumed) all the watch dials for watch companies.
In short - I'm not saying this 145.012-67 wasn't relumed. . .but asking why people think it may have been, and pointing out that the look of this dial and handset are consistent with at least two other examples of 145.012-67s (and Rolex Subs) that I've seen. I think this will be a great discussion, so please, let's talk!
cheers,
Mark
