Speedy Tuesday #2 ( arrivals thread )
You did it yourself?? 😲😲
It isn't hard to do. The holes are already in the strap. You just have to drive the needle through them.
Well I finally got the call, but I can't travel 9 hours (return) to pick it up as my shoulder was dislocated lol. So going to have it shipped. Hopefully all the markers are aligned. Going to have them check.
In another note, I asked for the bracelet to go with this, and I feel like only one of them is correct. the 1171/633 is a 19mm right? The ultraman is 20mm.
The 633 end link is 20mm. It can even be a touch wider so some filing may be required in order to fit them.
Ah - so many codes and I got them all mixed up. Risky business. Thanks!
and the one on the left is the standard speedmaster bracelet that comes with the big box?
It is. Is that a AD quote for AUD610 for the 1171/633 inc GST?
10XX just received from USA OB. They fitted an 1171 bracelet to it. The OB talked me into the 1171 saying it fits the older look of the watch. I’m a modern guy so the bracelet is just ok to me.
I think they were referring to your wrist 😗
Does it need filing? My OB won't fit it for me if filing is required. I have to order the modern Speedy Pro instead....sigh
I was told it needed filing & my OB was very happy to do it. YMMV
lucky you mate 😀
Don’t know about you lot but I couldn’t have a brand, spanking new bracelet filed whatever the circumstances. Must be my OCD kicking-in! 🙁
Believe it is just the 633 end links that need to be filed down, so that it doesn't scratch the case. I'd rather have the end links filed than risk scratching the watch case!
Yup with GST.
I got a guy from the OB calling me. After confirming a few things like no discount on accessories / bracelets, he said he knows about the filing of the 1171, but he said it's not needed. It's apparently the way you put it in. I dunno. He fitted it in a few ultramans already and non needed filing.
Went to the OB to try to change to new Speedy Pro bracelet, but they scratch the back of the lug like this already. I am very upset to be honest. Maybe I should stick with 1171/633 then🙁🙁🙁🙁🙁
Yes but the quality of the filing is user dependent. They could leave just enough sharp edge to scratch. Not worth the risk to me
That is totally unacceptable! Who did that, some kid??! I would complain, they just massively devalued your watch
