Searching for Omega Constellation Case 168.029 (gold)
Hi All,
I'm looking to purchase a gold case for my omega constellation 168.029. Have not had luck on Ebay yet. If you'd like to sell or know someone who might, please let me know! Thank you!!
Best,
Rob
IMO you have very little chance of finding a loose solid gold case. The reason so many movements and cases get separated, and perhaps why you have the former rather than the latter is that the high price of gold has meant many cases were scrapped, leaving thousands of orphaned movements and dials left over. I note your dial is solid gold. If your watch was mangled by a scrapper, perhaps they missed this rather crucial point else that would be in the crucible too.
IMO you have very little chance of finding a loose solid gold case. The reason so many movements and cases get separated, and perhaps why you have the former rather than the latter is that the high price of gold has meant many cases were scrapped, leaving thousands of orphaned movements and dials left over. I note your dial is solid gold. If yours was mangled by a scrapper, perhaps they missed this rather crucial point else that would be in the crucible too.
Thanks! Curious - how do you know my dial is solid gold? I can't find any markings on it that describes the gold (eg 10k gold filled etc)
Al
@padders Also, just to clarify, I don't necessarily need a solid gold case, can be gold filled as long as it doesn't look weird compared to my dial.
Your dial is marked OM at the bottom.
This stands for ‘Or Massif’ or ‘solid gold’
Couple of thoughts.
You could consider a Gold Cap case, or even a SS case with the fluted bezel which is 14k white gold but often has yellow gold hue.
Pictured below
Couple of thoughts. s
Pictured below
Do you have any idea where i could source these?
On eBay with patience.
However. Is that actually a C shape dial…?
Might just be the angle of my photo. It's a perfect circle dial.
He’s talking about the case style, the ref number you’ve listed is known as the C shape. How are you certain your dial is from that ref case?
With those indices I would suggest it came from a 168.016 case.
Edit.
But it would have to be quite a late version with the inverted text.
Thanks for clarifying - I'm actually not certain. I just ran it through AI and it told me that, but we all know AI can be wrong. Is there a better way to confirm this?
just looking into this a little further.
Excerpt from Desmond's blog - with the same dial configuration, it could be an integrated case style. (I always think of these references as being from early seventies but the serial of the movement fits for '69)
If so, there would be a hell of a lot of gold in the case and bracelet - worth a pretty penny on the scrap pile.
Except from Desmond's blog - with the same dial configuration, it could be an integrated case style. (I always think of these references as being from early seventies but the serial of the movement fits for '69)
This is extremely helpful - thank you! Can you think of any way to confirm the case model with 100% certainty? Obviously, it's going to be difficult to find any of these case models but I just want to make sure I'm focusing my search on the correct model. Thanks again!
Unfortunately, it is impossible to know which case the dial/movement left the factory with, unless you were able to get an extract of the archives for the movement - which is no longer available at present (and may never be).
This end of 60s/early-mid 70s Constellations have a limited appeal and therefore there is less information about the constituent parts - such as dial size.
If the 168.016 and 168.0045 dials are the same size, you could be on the look out for either case type - but I'm afraid that I don't know where you would find that information.
That’ll be a rather tight fit for the OPs movement…
Sorry, are you saying that because it's the wrong ref or something else? Thanks
