Rubber strap for Moonwatch 3861 now available in boutiques (video)
Not sure if anyone had a chance to test it, but reckon it fits on a 1861 as well?
I've updated my 1861 with the 3861 bracelet without problems, but no gap rubber straps are typically another beast..
I‘m wondering if the strap will come in size S for us with smaller wrists?
It does…😀
Can you confirm/share the part number please? Usually printed on the underside of the strap…. Thanks!
Rubber 310 20x16 blk dpl 1 catch L ref 032z017247
(Length 111.60mm, 115.00 mm)
Same except catch S, ref 032z017246
(Length 91.60mm, 95.00 mm)
Same except catch std, ref 032Z017245
(Length 101.60mm, 105.00 mm)
Love to see photos of this on a standard 3861… 😗
Just got my strap and deployant and happy to confirm it fits. Highly recommend the strap, very flexible and comfortable and completely changes the look of the watch.
Great to see the mod works,l but surprising to see you have the bracelet from the new moonwatch instead of the flat link for the A11 50SS.
I have the original flat link, I just like to have fun and swap things around every once in a while.
Maybe this is also an option for your A11:
Looks like you have the standard length. If you don't mind, what's your wrist size and how does it fit?
What is this? I think it would be nice on my Movado.
Custom made grey alcantara with patina stitching and lining from Aaron Bespoke Montréal.
Just under 7” and im using the 4th adjustment hole, so right at the middle of the available adjustments on this strap.
Thanks. I ordered the same and wear it at 7.25, slightly loose. Should be okay.
That 50th is so beautiful. I went back and forth on getting one new and kindof wish I had. It's so damn classy.
FYI- I’ve actually used a small drill bit and manually (by hand - slowly!) created a much needed new hole in between stock ones were necessary on two other omega rubber straps. Have had no issues with the new holes to date but obviously do it at your own risk…
That rubber strap look better than I expected. Thanx for the photos!
My strap is out for delivery today. I'll post pics of it on my 3861 tomorrow.
Arrived earlier than anticipated…kudos to the OB in Dallas!
