Rolex 1016 case and caseback
One of the most admired models in Rolex's history is the 1016, which I adore. However, what makes the case special and expensive? For $8500, a friend purchased the case alone. I am aware that the Rolex 1016 case is distinctive due to a number of distinctive features that set it apart, because:
-it has distinctive straight lugs,
-It features the iconic Rolex Oyster case, which is designed for water resistance.
- The bezel design is smooth is a simple and understated design
-Overall durability. As with most Rolex models, the 1016’s case is built to last. Its solid construction, combined with the high-quality stainless steel (often 316L) E.t.c
However, is it worth $8k to buy just the casing when you can get the entire watch for approximately $15k to $20k? What are your opinions? Many thanks in advance.
There is nothing special or intrinsically valuable about that case except that the price of replacement parts generally scales with the value of the watch. Depending on the reference number stamped inside, a vintage Rolex case-back might cost as little as $150, or well over $1k.
Hopefully, the serial number on the case corresponds to a gilt 1016, or he overpaid badly. The person who needs this case will have a beautiful gilt dial and an appropriately dated case-back, and a case that's so ruined that it can't be repaired/refinished. Of course, anyone who uses this case will have a frankenwatch, and they need to be ok with that.
Edit: Looks like I replied to an AI. ::facepalm1::
