oddboy
·Hi all,
I'm still working on making contacts and developing relationships with watchmakers in my local area. I've used three different places now, each with different experiences.
I just had a watch serviced, a cal 861 speedmaster, and the 'overhaul' took about a week. There was a problem with the hour recorder not recording which is fixed, and the watchmaker said it was fully disassembled, cleaned, oiled and regulated. Not much in the way of parts replaced other than mainspring and no pressure test.
Contrast that with one of the others, but for a cal 321 speedy. This is an authorized Omega repair center and the onsite watchmaker does all the work. In this case, the full service takes 8 weeks minimum (still don't know if it will take longer) and many parts replaced.
I know these are different beasts and cal 321 is harder to get parts for, and a lot depends on the condition of the watch itself. I'm just curious if an 861 can be properly serviced in a week by a local independent, or if this is a bit of a quick job and maybe not as thorough. I'm sure the servicing on the 861 would be 8+ weeks and probably double the price if I had taken it to the authorized repair shop.
What would you expect the turn around would be for a full service on either of these movements?
Insights and feedback greatly appreciated.
