Possible new 300m spotted on Daniel Craig
I’ve heard rumours a green due next month and either a white or blue next Jan before the bronze/ burgundy
A polar would be nice
I don’t think 2 mm is splitting hairs. Tudor seems to sell the Black Bay in 39 mm, and 41 mm just fine. People went crazy when that 39 mm was released. And while Christopher Ward isn’t a high end brand you can get the same Trident dive watch in 38, 40, or 42 mm. With 300 m water resistance and thickness around 11.5 mm. There must be a demand for these different sizes. I don’t think they would make them just because they can.
Remember—basic geometry from grade school—you have to square that difference. Going from 42mm to 40mm you lose about 130 mm^2 of surface. It’s a pretty substantial change, though the impact can also be affected by other factors such as the relative sizes of the bezels and lug widths, thickness and case shapes, etc. But having worn both the 42 and 41mm Seamasters (likewise 41 and 40mm Subs) I can attest from personal experience: even a 1mm variance in diameter can be quite substantial on the wrist. They wear totally differently.
My personal opinion is if you want a chunky diver with big wrist presence, that's what the Planet Ocean is for. The SMP should be a sleek and sophisticated diver. They nailed it with the first and second gens, they should be going back to those dimensions. Especially the thickness.
So for me, 40 mm is the ideal if you just offered one, but I could imagine Omega would potentially stick with a 42 and maybe offer a 39 in addition. I don't imagine a mid size 36 diver is coming back, I think that would sell too poorly in today's market. Honestly though, the diameter isn't the dealbreaker for me, the thickness is. I'd buy a 42 mm SMP, but I won't buy a 13+ mm thick SMP.
sleek and sophisticated is exactly where the Heritage diver is currently at.
There is very little about skeleton hands or a helium Escape valve or even a scalloped bezel that says much about sophistication. The SMP is a sport watch first... and I'm totally for that.
As far as thickness is concerned... omega's cases have come down even as their crystals have come up. Can anyone provide the case back to bezel height thickness on a Submariner? I keep seeing "thickness" as an argument over and over... but meh. Flat crystals aren't interesting or fun.
It is a sport watch first but it used to look sleek and elegant too. It's a bit of a trope but you only need to look back at how well Brosnan and (for one movie) Craig pulled it off in a tux. It wore easily under the cuff, even if the dial was sporty. I just think it used to do both well.
The Sub's crystal is essentially flat and flush so those measurements are virtually one in the same. The total case thickness inclusive of the barely proud crystal is 12.8 mm for the no date or 13.0 mm with the date cyclops.
Maybe most customers don't care about a tall watch but I certainly do. My SMP is 12.0 mm thick and my Railmaster, which is basically an AT, is 11.0 mm thick, and they both wear so well it's difficult to accept the 13.6-13.8 mm current gen offerings. Every generation has been thicker than the one before it, I'd just like that trend to reverse.
Putting my own opinions and tastes aside, the thickness complaint is very common. Go look at any new SMP post or release and read the comments, it's a constant criticism. Enough that Omega ought to address it. Even if they just target matching or beating the Sub and try and hit somewhere in the high 12's, that would be a reasonable goal.
It's really common complaint but I so often see people also say that you have to Discount the height of the crystal when you're talking thickness. There are so many rules and exceptions- SOMETIMES.
Honestly as much as anything isn't it the lug to Lug that interferes with a shirt cuff on the SMP?
Perhaps increments of 3mm would give the biggest bang for buck and span the range e.g. vintage 36mm, regular 39mm, sport 42mm, special ops 45mm. Respectively yielding area (pi * r^2): 10.18cm^2; 11.95cm^2 (+1.77cm^2, +17%); 13.85cm^2 (+1.9cm^2, +16%); 15.90cm^2 (+2.05cm^2, +15%)
No models would exist in all 4 sizes (likely only 2 or 3, dressier at the smaller end, sportier at the larger end), and not necessarily fixed to the 36 - 45 range, other ranges would work fine too e.g. 37/40/43, or 38/41/44.
Anyhow, not like it matters 😁 Just pondering
This exactly. The wearability between the older models and the 42MM is very different. I see the diver 300m as a sleek and sophisticated diver too.
I don't notice any real difference between my green Seamaster and my Peter Blake Seamaster when I'm wearing either. The newer Seamaster is heavier.
Is this the domed crystal that adds so much thickness?
I understand these, the 60th, NTTD, and Heritage are different, though, higher crystals and those might pose a problem for some. Incidentally, I do think crystal height can be an issue - knocking things off it - but it doesn't attribute to a thicker watch. It's all above the bracelet/strap line. It does make it harder to tuck under a cuff. My opinion and limited experience.
I'll stop short of saying none of the numbers mean anything, because they do. My 42mm/13mm/50mm Seamaster feels a lot different than my favorite microbrand's 44mm/13mm/51mm NTH Thresher. I rounded those numbers up to the nearest whole.
I don’t think everyone does. Just some of us. And I’d be just as happy to have a smaller option, rather than an exclusively smaller line.
My daily wear is a 43mm watch that’s all dial—I’m not doctrinaire about this. But I will say, once you get used to wearing a 36-38mm watch, switching back to something over 40mm starts to feel a little clown-shoes silly.
Maybe the point is: watches aren’t one-size-fits-all any more than shoes or shirts or eyeglasses. It’d be nice to have options in the SM pro line as we do with the ATs.
It’s just funny because I do have a 36mm smp 300 from the 2000’s and it looks tiny on my wrist, it feels fragile, even the clasp. I guess I’m used to wearing 44mm Apple Watch that when I switch to the smaller watches like the Bond 60th and my other SMP they feel just right. Even looking at my submariner that's 40mm doesn't feel chunky.
Looking back on it, Omega stopped selling 36.5mm watches late last decade, they skipped them with the current gen, but I totally remember seeing them with the 300m with the chrome omega letter and navy-blue ceramic dial.
Not just watches but it totally feels like we are getting less for paying more, I love the dates on a watch and could care less about symmetry, but I always thought it was odd that the 8806 movement, aluminum, steel upcharges was just because of "licensing"
but see that's the problem we all thought the new black dial 300m would be smaller and come out in 38mm, like josiahg52 mentions, they really don't feel 42mm because they are sleek and smooth unless we talk about thickness.
36.5 on a dive watch (I’ve owned one of those too) does feel a bit too small because a fair portion of that real estate is occupied by bezel. (Whereas a 35mm dress watch can be spot on for most wrists.)
I think a 38 or 39mm Seamaster pro would be ideal. If they could make it thin.
Meantime I think I’m standing by my Rio 2016 third-gen. 41mm, svelte with a solid caseback, ceramic, no laser cut dial… That, to me, is the era of Seamaster most likely to become a classic.
Massively underwhelming release for me. I just don't understand why Omega keep insisting on hockey pucks. It just baffles me. There is this misconception that with coaxial comes thickness. The DeVille has the same 8800 movement in the SMP and it's 9.9mm thick.
"Yes but that is not a diver watch case!!!"
Well, the 2254/2255 case is a diver's case and it's 11.8mm thick. Surely you can take a movement from a 9.9mm thick case and fit it in a 11.8mm case. Yes, some work will be required but surely it's not rocket science! Omega?? Hello?
Rant over.
Rant over.
First, I think that the DeVille isn't a diver's watch matters. Second, the cal. 8800 is 4.60mm thick, the cal. 1120, 3.60mm. The newest ceramic dial appears thicker than the 2000s Seamaster's, so how much are we talking about? Omega could probably get it under 13mm, but how much really? A few tenths? Of a mm?
I am sure they can work it out and get it to 12mm at least. Surely it won't be a huge task for one of the lead innovators in watchmaking.
They just want to stick to thicker watches. Perhaps they think that if they reduce the size of the SMP it will be too similar to the submariner? Probably research done by the same people who thought that the change of shape of the He escape valve to a toothpaste cup will be a big hit....
Look, I'll be the first to acknowledge that I don't like all of omega's designs and I don't agree with many of their design choices. But, sacrificing everything on the altar of thinness is honestly.. well, to be polite, it's not a very thoughtful approach. It limits what you can do with your case, your bezel, and it definitely limits what you can do with your crystal.
Omega's domed crystals are excellent, and quite frankly the bezel on the Heritage and on the planet ocean is spot on.
Can the cases be a bit thinner? Absolutely. But absolute thinness is not the answer. There's absolutely nothing wrong with a 13mm thick dive watch.
Having thought about this a bit more though, I will acknowledge that the whole reason I don't currently own a Seamaster professional is because, even though they fit me, I'm not a huge fan of the huge lug to lug.
Agreed, lug to lug also needs to go down. I get what you mean, but having a thinner case doesn't mean they need to sacrifice other aspects of it. All it needs is a bit of R&D. Look at the competition, if Rolex, Tudor, GO etc. can do it, so can Omega.
They managed to integrate a coaxial escapement into the speedmaster and thus created perhaps the best moonwatch yet. All they have to do is apply the same effort to the seamaster.
I havr to agree. If the Seamaster could come down to 13 to 13.4mm with a nice domed crystal, with a 40 or 41 mm case and a 48 mm lug to lug, it might just manage to be perfect enough to make everyone just a little bit unhappy.
Everyone, that is, on this forum. I've almost never see anyone on Reddit's Omega sub complain about the 42 mm size of the Seamaster Pro.
Agreed. They also need to inset the HEV crown into the case, as they do on the Planet Ocean and older Seamaster references. Having the crown rest on top of the case looks lazy and unfinished.
The current Seamaster just doesn't seem that big to me, on the wrist or by the numbers. 12mm vs 13mm, 41mm vs 42mm, the only gripe that might have legs is the lug-to-lug, ~47mm vs 50mm. That does make for a larger feeling watch, for sure. It may wear differently but it's not a huuuuggge watch. It's just not in comparison with previous generations. The 18mm/46mm/52mm PO is a big watch.
The current Seamaster HEV isn't done very well, agree.
