Please post your vintage zenith
the Zenith 12-4 is based off a Rayville Movt so it’s more likely that
Thank you for the information, I didn't know about the Rayville connection. Do you know if Rayville manufactured these movements for Zenith?
It certainly appears to be the same base movement. EDIT: The only major difference I see is an additional screw on the third/fourth wheel cock.
Hmm I was going based on the info provided by the seller, so we're always interested in learning further info.
i don’t know where the original info on this came from but it seems to be common knowledge that Zenith used the Rayville movement as the base for the 12-4. I don’t know if the 12-4 was made specifically for zenith. Check the Rayville 42. Very similar
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Rayville_42
Thank you for the response. On another forum, Hartmut Richter mentioned that he read about the Rayville connection in Manfred Rössler's Zenith book.
While that Rayville cal. 42 looks neat, it looks to be an entirely different movement than the cal. 12-4. The diameter is 20.0 mm vs. 26.5 mm, and the design of pretty much every component looks different. Below is comparison using images and data from Ranfft.
Rayville 42: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Rayville_42
Zenith 12-4: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Zenith_12_4_P_0
This is my latest acquisition, cal 2562PC.
Crisp case with some marks and nearly perfect dial. Like it very much.
Hi all I have just found another 0.0170.346 to replace the one I regretted selling a couple of years ago and this is a keeper
Hi all my watch is now complete as I've fitted a new old stock genuine Zenith bracelet so now it's definitely a keeper
Zenith XL-tronic. I love the continous sweep seconds motion 😀. And the micromechanics is faszinating, in particular also because it still works well after about half a century.
This ratchet wheel is moved 300 times per second!
Hi all Happy New Year to One and All
An update on the running of my 01.0170.346 it is running great (+2 seconds per day)
