Planet Ocean Thickness - Not so bad
That’s why you try it on before you buy. If the fit is not to your liking, you should simply not buy it.
I agree with you. That's why I don't own an Omega PO GMT even though it's more beautiful than most Rolex GMT's in my opinion.
I'd choose the Omega over the Rolex save the Thickness.
The Omega's design is so much more elegant and modern.... BUT 17.25mm thick vs 12mm thick.
Which is why I say, Rolex is "Function Follows Form" They created a Watch that looks and wears the way they want, and they said "Oh well, it's only 100M rated..."
Omega is "Form Follows Function". They Created a 600M Rated GMT and said "Oh well, it's thicker by 5mm"
And that's why I don't own a PO GMT . . .
I think the confusion started because the classic Rolex GMT looked a lot like a Submariner... But that was only because it needed a rotating bezel. It had a simpler crown, and thinner case back, hence only 100m WR.
When Omega made the GMT they based the design on the SMP, and for some reason made it 300m WR too. I remember Omega fans pestering Rolex fans in the forums at the time, asking why the GMT Master did not have a trip lock crown, why it was not 300m WR... The answer was always the same: because the GMT Master IS NOT a diver's watch.
The fact is that 300m (or 600m) WR on a GMT watch that does not have a diver's bezel is pointless. When diving you don't really need to know the time (let alone in two or three timezones !), you just need to be able to measure elapsed time: a bezel an a minute hand.
Now the GMT Master is as thick as the Sub, and has a triplock crown (though still rated to 100m), and that's why my GMT is a classic 5-digit:
And my PO is the no-nonsense first gen:
Both options VERY comfortable at what they are.
By the way, can someone tell me what's the thickness of the new 39.5mm PO ?
Thinner than the new 43mm but thicker than the old 42mm 2500coax.
I can look it up, but I tried on both before I bit the bullet and bought the LMPO.
https://monochrome-watches.com/smal...Seamaster PO is already,in the 43.5mm version.
According to the Article
The Seamaster PO is already a rather bulky watch, with a large bezel, large indexes and large hands. Even in this 39.5mm edition, it has a 14.16mm height - and over 16mm in the 43.5mm version.
The LMPO is what? 14mm?
If a wizard can reduce in 2 millimeters my PO 42 8500 thickness, I will give him all my collection, including the SUB.
I'm no wizard, but would love to give that a try... I have a rather sizeable mallet here that might just do the trick... 😉
...you will include all the boxes and papers, right ?
I have just measured my standard PO2500 and it's 14.2mm.
I would presume your LMPO (beautiful watch, by the way !) is the same.
I am measuring all my watch thicknesses tonight. 😉
Ok soo. Thickness:
Omega Ploprof Steel: 17.66mm
Seiko SBDX001 MM300: 15.27mm
Rolex SeaDweller 116600: 15.07mm
Omega PO LE 42mm: 14.50mm
Rolex Daydate 18038: 12.77mm
T H O R !!!
