Omega Speedmaster Marui
Hi @Archer , hope you’ve been well. I see that you’re a specialist in identifying marui watches. There’s one that caught my eye, would you be able to help verify the model number? It would be greatly appreciated! The photo provided was a bit blur but I see that the serial number is either 58351336 or 58391336
Serial number: 58351336
Article ref: 35233000
Serial number: 58391336
Article ref: 35105200
@Archer another one for you! SN: 57685611
Thank you so much for your help!
Serial number: 57685611
Article ref: 35102100
Hi @Archer, would you help to verify the model please?
SN 59784194
Thank you so much
Serial number: 59784194
Article ref: 35395000
thank you sir
btw may i know the year it was made pls?
thank you sir
I don't have that information - for that you would need to get an extract of the archives when that service is available again.
Received another request via PM from @Chasp - here is the result:
Serial number: 57693360
Received another request via PM from @Horvathn.hu - here is the result:
Thank you for the quick reply. Please be so kind and enlighten me in the following question: the concerned watch has a 3220 movement (according to the seller this was also the original movement, i.e. no upgrade has been made from an 1140/1143). Based on a quick serial number check (https://serial-number-decoder.co.uk/omega/omega.htm) I also understand that this watch was made in 1998. I am confused: I thought the 3220 was first introduced in 2000. What am I missing or misunderstanding?
thank you!
thank you!
First issue of the technical guide for the 3220 was 2004, so yes early 2000's for sure.
The change from the 1140/3 to the 3220 is mandatory when serviced at Omega, so if it was serviced there, the movement would have been swapped if it had the 1140/3 originally.
Serial number: 57685628
Is the Marui both a panda dial and all white because I bought one as a gift a few months ago so it would be nice to get a quick confirmation.....
Reposting my original comment from 2020 due to no response as I just had a question about the dials..... is the Marui Speedy Reduced only the reverse panda dial? Crown & Caliber sold me an all white Speedy Reduced stating it was a "Marui" but I'm now thinking it's more like an "Albino Speedy Reduced" or something similar.
Thanks for the help!
@Archer Can you pease verify reference 3510.20.00 SN 53217701? Thank you!
Serial number: 53217701
Article ref: 35105000
