Omega Speedmaster Marui
58052748 Hi, Archer! Can you help with serial please ? Much appreciated!
If it's being sold as a Mauri, it's a converted watch...
Serial number: 58052748
Article ref: 35105000
Request from new member airgio...
Serial number: 57722966
Article ref: 35102100
Thank you archer!
Hi, Archer! Can you help with serial please? Looking between two different Marui's (3510.21)
57693412
58408480
57693412
58408480
Serial number: 57693412
Serial number: 58408480
First issue of the technical guide for the 3220 was 2004, so yes early 2000's for sure.
The change from the 1140/3 to the 3220 is mandatory when serviced at Omega, so if it was serviced there, the movement would have been swapped if it had the 1140/3 originally.
Hi Archer, that's an interesting bit of information. Can you tell the reason for the mandatory swap? Were the 1140/3 movements such bad movements that Omega does not want to service them any more? Would this swap still be made today, i.e. does Omega still have 3220 movements or would Omega simply reject servicing a watch with a 1140/3 movement? (Which would make owning a watch with a 1140/3 movement not overly desirable...)
They still have movements so no worries about that.
Hi @Archer, could you please also lookup the serial of a Panda Marui I'm planning to buy? Its serial is 57693334 and it is advertised as reference 3510.21.00. Can you confirm that this serial matches the correct Panda Marui reference number?
Serial number: 57693334
Wow, that was fast! Thanks a lot for all the great help you are providing here!
Now, I can pull the trigger and buy the watch 😀
Hi Archer, how are you I've been sold a omega speedmaster reduced serial number 51657578 well that's what's on the inside of the case back anyway. Is this a genuine albino dial reduced please? Thank you
Comes back as REF : 38105000
Hi @Archer I would appreciate if you could look up this marui reduced please? SN 59221776 Thank you very much in advanced!
Hi Archer.
Hope you're well. was hoping you could help me with this one -
i have a serial number on my reduced case of 57910.
What reference does this align with? Huge thank you for answering so many of these!
Not a Mauri, so a modded watch...
Serial number: 59221776
Hi Archer.
Serial numbers are 8 digits, so I can't see anything without the full number.
You're an absolute legend! Almost lost a lot of money. A seller overseas offered me marui with this card
Serial number: 57910104
Article ref: 38027351
