BlackTalon
路路This Space for RentAs far as the case cracking/ breaking is concerned, I really don't know what Omega could say about it. You can't really just test it by dropping it 3 feet onto a particular surface, as the angle it hits at, etc. will result in a wide variation in the actually stresses. The lugs stick out like cantilevered beams, plus they not only have a hole that results in a weak point, but they also have a springbar pressing into them. So I would think the lugs would be especially vulnerable, although I do not know enough about the wall thicknesses of the case in general versus the lug thicknesses. As far as robustness of the sides/ back of the case are concerned, hitting something that is fairly flat means less concentrated stresses then hitting the corner of the same object. Since the case is round, an impact to the side essentially gets supported by an arch, which is great in handling compression loads. Unless that load is extremely focused, in which case the arch action would not really help. And the caseback would be behaving similar to a slab, in that a perpendicular load would put one surface in tension and one in compression -- and brittle materials tend to be much weaker in tension. So an impact on the caseback could be more potentially damaging then a similar impact on the side of the case.
I'm sure the case 'structure; could be analyzed for different loads/ impacts using finite element analysis, although it would be an expensive undertaking. But with no real standards for watch cases in general, what would Omega test for? If a standard were developed by ISO, etc., then should all metal cases be tested as well?
I suspect the end result of al this is simply "It's an expensive watch -- don't bang it around or drop it"
