Omega Seamaster 2551.80 Mid Size 36mm Blue Wave Bond Auto - Legit?
Looks like a perfect fit—wear it in good health!
Thank you!
Question - How tight do you wear yours? I’m used to leather straps wear they fit snuggly and don’t move around. When I got this resized, the guy said it should be loose so it can move around but not spin. This felt uncomfortable to me so I had it done tighter.
I did some research but can’t find an consensus. Does it look overly tight to you or is it fine? It feels snug but not tight.
Thank you!
Definitely not a consensus issue---different strokes for different folks. It looks to me like you've got it well sorted.
I read somewhere (probably several somewheres) that a bracelet watch should be just loose enough that you can slip your index finger between the clasp and the bottom of your wrist. That should mean the watch isn't so tight that it leaves a mark on your wrist when you remove it, but also not so loose that it flops around when you move. I tend to follow that guidance. It's worth mentioning that over the course of a given day--especially if you go through temperature changes/indoors/outdoors--your wrist will swell and contract, and the difference can be uncomfortably noticeable if you wear the bracelet too tight. This is why some people really want micro-adjustable bracelets, like you get on the newest Seamaster divers. I'd argue that if you size it right to start (see above), you should be fine all day every day.
But some people want their watches looser. Roger Waters of Pink Floyd wears his Rolexes so loose they sit on his forearm. I have a very heavy precious metal Omega that I tend to wear on the looser side because the weight is so well balanced (between the case and bracelet/clasp) that it barely moves, so I just find it more comfortable that way. But with my Seamaster diver, I've got it tuned just-so: no wobble, no skin-marking.
Over time, you'll find that the bracelet does loosen up a bit as the springbars/pins start to bend a little---that's normal. The watch is conforming to your wrist, you could say.
Again, thank you for your insightful response.
I'm at the level now where it feels firm but it does leave a mark. It doesn't feel too tight though. I may try and have a half link put back in to see if that's the sweet spot... will see how it goes.
Thanks so much.
Nice, enjoy it.
Too loose a watch will hit mostly everything all day long too. And the scratches to go with it.
@Annapolis Made it and got the bracelet resized to fit snuggly on my wrist!
Really happy with it. Thanks again for all your help and thank you to everyone else in this thread. The 41mm fits exactly as I imagined the 36mm fitting so I’m beyond thankful for all of you for bringing to my attention.
Congratulations! Looks very nice...
Also a small wrist man here. I have both the mid size SM and the regular SM Chronograph. Great wears!
Nice! What is your wrist size? And do you know what the lug-to-lug size is for the midsize? (I know the lug width is 18mm). And how would characterize the overall size difference in person?
