Omega Planet Ocean 39.5 Rubber strap?
did the 38.5mm aqua terra rubber strap fit your 39mm planet ocean?
I can confirm fitment on 39.5 PO. Pretty close match in color, but the AT blue dial does not match this strap's hue 100% either. Indoor lighting seems to match the blues better than outdoor. I imagine this isn't a problem with black on black. As for fitment, it is almost perfectly flushed with the case. You wouldn't be able to tell unless you looked closely at the metal endlink portion that sinks ever so slightly below the case. On the AT the sides and middle end link sit higher on the watch.
