Omega Peter Blake ring misaligned ?
OMG, I was reacting on the question in the first post, if it is a simple fix. That`s all. Simple reply to simple question. everyone can make a decision, if is capable of DYI, or has to go to watchmaker...
After that you quoted my post with the "glue extended version of true", which I reacted as I did, as I`m watchmaker and I`m never came across glued bezel insert on SMP watch. HAve a good day sir.
Have a good day you too, sir.
Just to confirm and reply to everyone
Ended up buying it for around 1200 decided to take the risk on that amount , watch was original however needed full service because of moisture on the dial , obvious bezel misalignment which was indeed not glued , over polished case and then some
My last comment on the misaligned bezel: This is very often from factory, as bezel is being completed before being pressed on the watch. As it is 120 click bezel, the perfect alignment is then just a matter of luck... can be corrected by procedure described by me above.
