NTTD bracelet options?
Hi all, I was curious if those of you who own the Bond NTTD watch also own the older 42mm titanium Planet Ocean. I’m not really a fan of the mesh bracelet that comes with the NTTD, and seeing as the 42mm titanium Planet Ocean has the same 20mm lug width as the NTTD, would it fit?
It will look different. The PO is made of grade 5 titanium not grade 2 like the NTTD.
Best
Alex
The strap I got doesn't have links or holes for a buckle or clasp. The clasp is adjustable along the full length and locks in place. Bit like a cam or lever lock.
This does make it really easy to find the perfect size.
Oh yeah I meant the "links" from side to side, ~16 for the omega and ~30 for that first strap...
I do think that aftermarket strap is a finer mesh. So, as you pointed out, more links.
