Need help with a cal 20F
What I know is that the movement is a cal 20F from the 1930's produced in some 48.000 pieces.
The cosmetic condition is very very good for its age I think.
I'm not sure about the dial. It seems to be a redial ( or rather a new one made ).
At least I haven't seen a 20F with a dial even remotely similar to this one.
Dial feet at the correct place but that could've been done by a decent watchmaker...
( The golden colored hands look factory made and a perfect fit for the movement, those look genuine to me. )
The same goes for the staybrite steel case.
I usually see thick square lugs on the cases housing a 20F, not wire lugs like the ones present on this one.
What's your opinion on the dial and case? Does it have any value like that? It runs fine.
Thank you !
Case fine. Dial a bad repaint. Value as is? Maybe around dollares 350.....kind regards. Achim
Thank you very much for the information. 😀
