Deafboy
··His Holiness Puer SurdusI will have a micrometer next week to measure the thickness of the mainspring. 👍
The plots are quite typical of the vintage watches I service (I've had much worse in some very old Elgin wristwatch movements). Youtube videos of watch adjustments of modern movements look much cleaner on their timegrapher. Is it because of my timegrapher software, old movement design and manufacturing, worn movements, too much lubrication, wrong lubrication, noisy environment, etc I don't know.
Can you adjust the gain on the timing machine or software?
By the way I checked a few sources I have and the lift angle for the 23M appears to be 46 degrees, rather than 47. This would mean it was rebanking at an amplitude as low as 310, which would be unusual (not unheard of, but unusual). Have you tried letting the mainspring down, and rotating the balance by hand (tweezers) to estimate the number of degrees required for the roller jewel to strike the outside of the fork horn?
Both methods concurred: from equilibrium position I obtained 330 degrees in one direction and 337 degrees in the other. The timing software shows about 315 degrees on the onset of rebanking.
So first question is what is the size and type of end on the mainspring you installed? Based on Bestfit books, the spring should be 1.20 X .10 X 343. Not sure if you simply ordered one from a supplier and asked for a spring for that movement, but you should note that when suppliers don't have the spring you need, they will often send the "closest available" and even a small change in strength in particular can make a huge impact on amplitude. This is why when I email a supplier and ask for pricing, I always tell them that if they don't have the exact size I'm looking for, let me know what they are proposing as a substitute.
Second is, are you sure what you are getting is rebanking? If you have a timing machine, has the lift angle been set properly, and if so what is the amplitude like before you get what I assume is a very fast rate? Have you demagnetized the movement as part of the service? I typically demagnetize twice - once before cleaning and again when the movement has been reassembled. Is the balance spring free of oils and dirt? All this need to be checked.
As an aside, although most of the time you fight to get more amplitude on a vintage watch, there is nothing quite as frustrating in my view as fighting too much amplitude, if that's what this really is...
For the regulating pins, they needs to be parallel and properly spaced. What you have done in bending the one pin up high will cause dial up and dial down rate differences. So you need to put a double bend into the pin so that you can close up the gap if needed, and also keep the pin parallel to the boot that can turn. Here's an example of the opposite, where someone bent the pin out at the bottom:
And it had to be bent back to be parallel again to eliminate the large positional variance from dial up to dial down:
So in your case it's tough to see in the photo you have posted, but you may need to bend it in towards the boot up high, and then put a second bend in just under the first bend in order to keep them parallel.
As for the balance spring shape, can you post a clear photo of the spring at rest? I've not serviced a 23M (although I have a 23Z in the shop right now) so I'm not sure what the spring is supposed to look like on this one specifically, but I really need to see a shot of the balance at rest to see what is going on here.
As I've said before on the forum and to you in PM's as well, learning how to fix things like automatics and chronographs should only come after being able to really get a proper job done on a simple manual wind watch. 90% of the skills you need are used on a manual wind...
