SeaMSTR
·Good morning OF.
I bought a 1968 Ladies Constellation 568.001 (With automatic 682 movement), and had it serviced at the end of 2021 by a very reputable watchmaker, recommended by many on this forum. The service has a 12 month guarantee.
My Girlfriend doesn’t wear the watch daily, but perhaps every other day, which means the watch is left idle for over a couple of days every so often.
I have read the threads on here about giving automatics a jump start with a few winds if they are picked up and are not running.
if the watch has stopped, I usually give it 30/40 winds (to fully wind the main spring) and it will keep time all day, however when it is left over night for 8 hours or so, I will find it has stopped in the morning.
The watch was worn yesterday evening for 5/6 hours and placed on my watch winder overnight as an experiment. I have just looked at it and note it has lost 15 minutes over night, but is still running.
Before I contact the watch maker, to discuss sending it back for a check up, what are the sure fire ways of testing the power reserve and time keeping?
What power reserve can I expect from a ladies
Automatic, do they generally stop if left overnight, due to the smaller (I’m guessing) main spring?
How many manual winds should I use to ensure the watch is fully wound before I try and measure the power reserve?
I was planning to fully wind it, get her to wear it for a day, check the time it is taking off in the evening, and check in the morning to see what time it stopped (if not still running).
Thanks for any help offered.
