Someone's put up this
1943 38mm OmegaPurchases made through these links may earn this site a commission from the eBay Partner Network on ebay.
It is said to have the model number of 2319 (although the pictures are too blurred to be certain), with a 30T2 movement. I found this confusing cos if you check the OVD the closest match is a MI2319 with a 30T
1 movement with a dial that looks quite different.
I tried googling using 'jumbo' and '30T2' as keywords and found a wide range of different dials. One of Mike's
prior posts also mentioned the serial # should be in the 9m range (and this is a 10m number), and
Lou's 2319 looks rather different too.
So is this a re-dial, and a frankenwatch to boot?
I suspect it is, but as I'm still learning, would love to calibrate my assessments to the experts. Thanks!
