Help With Cal 600 Omega
Greetings,
I’m considering a vintage Omega advertised to contain the Cal. 600 movement. The watch seems to be in good condition with original parts, but I wanted to get an expert opinion before committing. The seller says the watch is 37mm including crown, which is consistent with my research of similar models.
Thank you for your help
That is a pretty poor example of a pretty run of the mill Omega. The plate wear would be a red flag for me since there is no easy way to improve on it. It would need to be very cheap indeed for me to show interest, like ~£100 or less. If it needs a service, and it likely will, you would never see your money back on it even at that minimal outlay after adding that cost in.
