VanDamme
·Hi guys,
Hoping to get your thoughts on this Tudor. The seller notes it as a circa 1959, Ref 7965 Tudor with crenellated bezel. The watch has a diameter of 35mm excluding the crown. The watch also comes with the original box signed by the retailer as well as the outer box.
The entire package appears to be in great condition. The case looks flawless and the lugs (with brushed finish still clearly visible) seem to be untouched unless it was remarkably refinished. The outer caseback is also completely unsigned unlike others I have seen. The seller wants approximately $750. This is the same seller I bought this from... https://omegaforums.net/threads/thoughts-on-this-connie.30473/#post-344363
Any thoughts on the watch or advice on whether to pull the trigger or not? Seller's pictures:
