Help with 60's Seamaster
Hi All,
I recently inherited a Seamaster from circa 1960. I was hoping that the community might be able to help identify a bit more about it. Any assistance would be great.
Looks nice but the fonts used there suggest to me it’s had a replacement dial (as opposed to repainted) at some point, probably within the past 20 years. Your estimate of age is likely about right but to be sure the detail you need is on the inside of the caseback. It might well be a locally produced case as I haven’t seen exactly that case design before.
You think a omega service dial? For me it looks more like a repainted dial. The font IMHO is a bit too sloppy (dont know how you write this😁).
It looks like a redial to me. The font on "Seamaster" is quite uneven.
I guess that is perfectly possible. The picture isn't of fantastic resolution so its hard to be definitive, but the fonts used there, whether via service or redial are those only seen from around 1980 onwards so what we can be certain of is that it isnt the original dial finish. It amounts to the same thing really. It is no longer original.
If it’s an heirloom from someone you cherished you’re probably not planning on selling it, but even if you did decide to, it’s a very attractive gold Omega.
Okay, if some collectors have concerns about the dial all that means is that they would hesitate to bid for it.
But, so far as you’re concerned you can enjoy it and most people won’t know or care about the integrity of the the dial.
As a regular OF member you get to see some real dogs of watches, where the dial, despite being original, has significantly patina’d or otherwise deteriorated, but are loved by their owners. Yours is great whether as a beater, for best, or both. Enjoy it.
Thanks for your help. As you say Spruce, It's not for sale, but good to get some info on it nonetheless.
As an example, here is my damaged dial:
Looks great.
Took me a while to spot it but hardly noticeable - probably fades to insignificance when you wear it regularly.
Looks great.
Thanks! Yep, and the chunky hour markers steal the show.
Looks like a bit of moisture got in there. If you hadn't said anything, I wouldn't have even noticed. Nice watch!!
