Help me identify my grandfather's Omega
Hi everyone, I recently inherited my grandfather's Omega. He passed before I was born (in the early 80s) and another family member had it until now. Nobody in my family can recall when he got it, so there's not really anyone I can go to for more information.
It's a small, square face mechanical with a 14k gold case. The face and case don't have a model name or any other obvious details for me to look up.
I know it definitely needs a good cleaning and polishing to get back to its former glory.
Would love any help you can provide to help me learn more about it.
Thanks!
It looks to be a US cased watch (14K Gold).
At the time, it was simply a "Gents Omega Watch" as not all Omegas were given "model" names (Seamaster et al).
On the inside of the caseback there will be references stamped to give you more information about the watch.
The case can be opened with a blunt knife held across the lugs and under the lip of the caseback. If you're not confident, see a watchmaker (not the battery changer in the mall).
Go easy on cleaning it up, heavy polishing will soften the look of the case, the crystal can be refreshed with a plastic polish, and if it's to be worn, a service is recommended to prevent dried oils/grease from causing undue wear.
Thanks for the quick response! I guess I was thinking more that the dial needs a cleaning, as there's a fair amount of visual gunk. If I was to take something like this to be serviced, do you have any idea what sort of price range to I'd be looking at? I've never had a vintage or luxury watch serviced before.
Service cost is dependant on what country/region you're in and who you use to do the service.
If you're in the US, I'd guess between $300 to $600.
Thanks! I also just opened it up, and here's what I'm seeing on the caseback. Does this tell you anything more about what it is or what year it's likely from?
If you Google "Omega DD6842" you'll see a lot of identical watches.
It probably dates to the mid 1970s.
The serial number on the movement will give an approximate year.
Dial cleaning is risky business. You can read about it here.
https://omegaforums.net/threads/can-vintage-dials-be-cleaned-polished.117911/
I think the watch looks quite nice. It shows some age, but looks great at 50 years old. I would have it serviced and put a fresh strap on it. It will be a great piece to remember your grandfather by.
Owned a similar model in 14kt white gold. Should have a caliber 625. I put a nice black lizard skin strap on it.
Not an every day watch, but good to have for special occasions.
If you mention location. Might help in finding a watch maker close to you. Simple movement, so nothing complicated in the servicing
DON
