Help me find the watchstraps for the Omega 176.010
Hello all,
I am currently looking forward to buy the Omega Seamaster Yachting 176.010
I am new to this could you please help me find the brand of the straps that I want to get for the watch?
The straps are found on the photos below
Thank you for your help!
Top strap looks like an authentic Omega strap as you might have seen in the 70s. It might say “GAF 64” behind 12 o’clock side
Ok thanks, would you know where I can find the original strap?
I don’t think they are in production but I’ve seen it in blue on eBay recently
How about a bracelet? The bracelet is an 1162 with 172 ends for these and it suits my watch👍.
Good luck, Chris
Good luck, Chris
Nice, is this the original one?
I believe so and the watch came with it. Somewhere on here there is a list of case references with bracelet and end link numbers. I can't find it easily but, it's definitely here somewhere.
Cheers, Chris
Directly from Omega. I got a black one three years ago.
The steel 1162/172 can be found quite easily as later service bracelet … to my mind, this is THE only real bracelet for the Yachting.
Also suits slightly worn watches ...
Hello all,
Hi, the first is a photograph of my own watch and i confirm that this is a Benarus rubber 22/20mm strap, which is very close to the vintage Omega 'GAF' strap (although slightly different). Comparing both, the Omega has slightly smaller square openings.
I do think it does suit this watch quite well and even tried it on my Flightmaster with equally good results.
The 176.010 is on a Tropic at the moment.
Good luck with the 176.010 hunting.😉
X
