hotwheels
·You can, your not listening. It’s just that they are not going to say you can use it for diving.
My point from the start is that the industry use wording which I believe is misleading, so if I want to dive to 100m would my watch be waterproof at that depth if it says 100m, yes? But other factors would mean it may fail. And if I can’t dive to 100m how else would I be taking it 100m down......misleading
I am giving you the opinion of a normal consumer, who will be mislead into buying a watch to dive in
No one (apart from @Hotwheelbill) is saying it will fail. The watch will be fine at 100m. The issue is it can't be labelled as suitable for scuba as it doesn't have a uni directional bezel as required by ISO 6425.
One thing I'll partially agree with you on however, is the free diving section. I'm not sure why they separate it from simple immersion in water (down to specified depth rating).
You are confusing water resistance, which is a stand alone property of a case design, with suitability for a specific activity such as scuba diving.
"But other factors would mean it may fail" makes no sense at all in this context. It means it might not be suitable for the task, so you may run out of air, but your watch won't leak unless you take it deeper than the rating...
If someone buys an AT rated to 150 m to dive in, then they probably shouldn't be going diving...
What else would I use the watch for at 100m down? I’m not confused as above would I be covered by the warranty?
My view is you would not be covered by warranty looking at the above chart,
if it’s not a dive watch fair enough so why do they put the 100m on??
I am listening, and I do understand, I am giving you the opinion of a normal consumer, who will be mislead into buying a watch to dive in as the industry throw around depth figures that unless you look into more closely will come unstuck, how do you think you would get on in court if your watch failed reading the chart above..........good for 100m yes, but you can’t dive to that depth as some other factor may come into play as you have clearly stated, then why oh why use the depth to sell the watch, the only way your getting that deep is diving !!! Sorry your not listening.
Change ID to 'spinningwheels'? 😁
This topic has been discussed many time in the past, in numerous threads on OF you can read. Your take on that chart is contrary to how it really works (which Archer has already covered). Your opinion on what it means and what would happen 'in court' does not reflect how it really works.
Well several people, including an Omega certified watchmaker are telling you otherwise, but you clearly have your own opinion and aren't interested in arguments/evidence to the contrary.
Then why use those terms to promote something that is not warranted
But if your going to use depth as a big thing then warranty it and give it all the components required to do that job.
A few things actually movement might fail from temp or become inaccurate from temp below freezing. Pressure may cause impingement on hands and stop the watch.
Both of these are maintaining water resistance but the watch would fail.
"A manufacturer may point you to their terms", "I don't think you'd do well in court".
Is this the basis for your concern/argument or do you have anything more substantial. People are presenting you with facts, and expert opinions and your counter argument is basically "no, I don't think that's true".[/QUOTE
What could be more of a concern than loosing thousands of pounds falling foul of misleading advertising and a misleading warranty?
Answer the question if you can, if not don’t attempt to put words into my mouth there are plenty there already,
