Is that not a bit odd? As I understand things, the 1441 is the only thermocompensated movement of the three and would therefore have better accuracy than the other two. From a consumer viewpoint, the accuracy specs quoted in the user manual are the specs that matter as they form part of the contract of sale.
Not odd to me. Does you car have the same HP as it did the day it rolled off the assembly line? Are you going back to the manufacturer 30 years after it was built to tell them it no longer meets the contract of sale? Let me know how you make out with that. 馃槈
No, but if when serviced, my watch will no longer meet the specs that it was originally quoted, I expect to be told, rather than simply having the performance parameters shift without my knowledge. I'm sure if say in the unlikely event that Omega changed a caseback gasket material and this affected the water resistance of a watch, lowering it from 300m to 200m and the technical instructions were changed to reflect this, you might mention it to a customer?
All very interesting, but perhaps I in my ignorance still don't quite see why it's logical to group three movements together under the same accuracy parameters when one is designed to be more accurate via thermocompensation. The only slight indication that there might be a difference is the superscript "2" next to the 1441 in your table, but I'm not sure to what (if any) notes it refers.
Also, in the information above, the statement "Our workshops reserve the right to replace the hands, crown, push buttons, and crystal of your watch by original pieces or by brand components if their choice that are comparable, aesthetically similar and maintain the same functionality." (my emphasis) would imply that whatever is done, be it service or replacement of a 1141 movement, the returned timepiece would meet the accuracy parameters as sold i.e. +/- 10 spy.
Now, I can understand that quartz movements might degrade and lose accuracy over time. What I can't so readily accept is a repairer/Oem can detrimentally alter the functional parameters against which their product will be judged as satisfactory during official servicing without telling the owner.
For practical purposes, I suppose you will still have a very accurate and useable timepiece, but if +/- 10spy is important to you, you might not be happy.
Anyhow, I'm shortly off to a civilised (I'm driving) Hogmanay gathering, so a Happy New Year to all when it arrives.
