Crystal and Crown for Seamaster Cosmic 2000 166.0218
Hi OF,
I'm trying to find the correct part number for the crystal of a Seamaster Cosmic 2000 - 166.0218
Here's a picture of the same model watch from the interwebs.
Can someone help me out with the part number? Also, I'm assuming I should be looking for the crystal with the yellow gilt ring, right, or does it matter?
EDIT: Found the crystal. All I need now is the crown. However, it seems there are 2 different crowns for this case:
4.5MM X 2.75MM TUBE 2mm
4.0MM X 2.85MM TUBE 2mm
Can someone confirm the correct crown size for the watch pictured below?
Thanks for any help!
Crystal with a yellow tension ring is PX5249.
Silver one is PZ5249.
Awesome!
Just curious…is there a reason to choose the yellow ring over the silver?
Thanks again!
The yellow ring has much greater holding power and also imbues the movement with incredible anti-magnetic properties.
Gold or gold plated watch, or a dial with gold hands/indexes = yellow (gold) ring.
Stainless steel with silver hands/indexes = silver ring.
Hahaha! In that case, I’ll take two of each!
So, silver tension ring for my version then.
Thanks again!
I’ve edited the original post to request additional help on identifying the proper crown.
Thanks all!
Measure the tube clearances on your case.
Thanks all!
Okay well in response to your PM the other day I did give you the part numbers - posting them here for all to see, as well as the stem parts you asked me about:
Crown - 069ST42527
Stem - female portion that goes in the crown - 081ST9992
Stem - male portion for the movement - 72210101159
Crown - 069ST42527
Thanks Al! This is great.
Just saw the PM again. My mistake.
Thanks everyone. Much appreciated!
