Cleaning your watches in an ultrasonic cleaner
Always wanted to ask @Archer
When doing bracelets do you put anything between the wire basket and the bracelet to stop scratching. ( have not used one yet due to not knowing )
PS it's a good one in the lab at work not a $20 one..
Interesting thread...to answer your question, no I don't put anything between the bracelet and the wire basket. I just place the bracelet with the inside (that would touch your wrist) on the basket and run it that way, and I've never seen any scratches result. Just don't put anything else in that might contact the bracelet, or let one part of the bracelet fold over and touch another.
An ultrasonic cleaner is actually quite violent. I wouldn't insert a whole mechanism such as watch movement without first dismantling it in parts. That still applies in the case if the whole watch is dipped in the cleaner and no liquid reaches the mechanism (as you seem to suggest).
Certainly the watch head should not be put in an ultrasonic cleaning tank, primarily because the chances of it leaking are much higher. But watch movements are run through ultrasonic cleaning machines fully assembled (with hands, dial and date indicator removed) all the time. If you have a Rolex and had it serviced at a Rolex service center, this is how it was cleaned initially. Then of course it was fully disassembled and cleaned a second time while apart...
In summation, don't put a complete watch in an ultrasonic cleaner. You are likely to do more harm than good. Try warm water and a clean, soft toothbrush instead.
Well that takes all the wonderment out of it! 🤪
I corrected that one for you.
I'm pretty sure that the COSH guidelines say you need to wear two, and a full body protective smock.
Google how a ultrasonic bath works.
And advice from a watchmaker in a post above would be enough for me
Should be fine if you are removing the movement and dial first......
You never clarified if you remove the movement and dial. Do you? If you do I see no problem, if you don't it is my opinion (please note it is an opinion) you are playing with fire.
I can't imagine that ultrasonic waves can do any good for the inner mech of a watch. Seems counter intuitive for sure.
BTW you ask a question, get a ton of responses saying its bad and then still ask the above? I don't get it.
You really have NO idea. Do you.....
An ultrasonic cleaner uses water, not fire! In fact, if you were playing with fire, that would be fine as you could put it out with the water! ::stirthepot::
DOH ! !::facepalm1::
You all have given me opinions. But no facts to back it up. When I ask for facts, or why you believe an opinion. I don't get one.
And to answer a previous question, the complete watch and bracelet is placed in the cleaner basket. So, explain why it is bad for my watch, and what the degradation mechanisim is.
First off, what an arrogant thing to say. Have you done any research to prove that what you're going is a GOOD idea?
A quick Google will tell you that:
1) vibration is not good for mechanical watches
2) At least one of the watches you mentioned isn't hugely water proof, so submerging it in water, and then having the water behave in a way that's designed to break down grease, but that can also distort rubber seals is an even worse idea.
And for nothing, I'll throw in number 3:
3) None of us have to justify our opinions to you. No one here is the watch police. Nor are we compelled to do your homework for you. You obviously have concerns or you wouldn't be asking if it's a bad idea - despite the fact that you already do it.
But when you do something dumb, and break one of your watches by putting them in a vibrating pot of water, after 20 people have given their opinion that it's a dumb idea, please don't come crying.
And equally let us have the serial numbers of your watches so that we know to avoid them.
Just my opinion there, sorry that I left the facts in my other Internet forum.
Give us facts why it's good to do....
Show me one piece off literature from any watch company that says to do it. I bet will have to troll the Internet for a while.....
The facts are that it can/will cause water ingress into the watch case.
You have been given answers by qualified experienced individuals and don't believe anyone...
Even if he were to take the movement out, I wonder if he thinks these would make a great case back remover. Personally I think they work GREAT. Of course you need an air compressor. And as a bonus they also work wonders on stripped bridge screws.There has never been a case back I couldn't get loose!! ::stirthepot::🍿
