Can anybody help?
Hello knowledgable hive,
I hope this is the right place to ask...
I have got two 8 days watches from which I cannot identify the makers of the movements.
Both have 15 jewels and 3 adjustments
Here we go:
8 days movement / diameter of movement: appr. 50mm / 22´´´
It is built into a large case which might have been mounted in a deskclock (winder at 6).
The second is mounted in a beautiful Gubelin marble deskclock with purple translucide enamel
also 8 days movement / diameter of movement: appr. 42mm / 19´´´
No markings below the balance.
Has anyone of the OF family a clue about the movement makers? Help would much be appreciated.
Can’t help but that second one is amazing!
I checked my Bestfit catalog section on 8-day clocks. Nothing matched. The first one sort of resembles 8-day movements made by Sandoz. The second one is marked Gubelin, and they made a lot of clocks of this style. In short, I’m guessing!
While I was searching, @rendo replied with what appears to be spot on for the first one. I found the same listing, and I think he’s nailed it!
The second one is similar to the Lemania I found in the Bestfit catalog:
