M'Bob
·Are Speedmaster cal. 321 dials/hands/movements as an intact unit swappable with a cal. 861 Speedmaster case, and vice versa? Assuming the stems stay with the movements?
Thanks. Do you have a sense of where those adjustments tend to need tweaking when they occur - the case, dial, movement, etc.?
No, the stem was fine but a 861 crown couldn't be used because it didn't fit the crown tube of the 321 case.
I simply reused the crown and stem assembly, so I am not sure about combining the 321 crown to 861 stem. But I think the stem issue is really trivial compared to the other things you might run into, like pushers being too long for the movement to fit, or dust cover too high for caseback to fit. (I ran into these issues recently)
I would be keeping the dial and hands of the '57
Sounds like a rather bold project to me!
Whilst I cannot answer your initial question, I suspect marrying the ‘57 dial to a 321 movement won’t work without rather mayor intervention. The dial feet positions of a 321 differ from those of the 861 / 1861.
Dial feet position should be fine. But the thickness of the 861 dial feet is different to the 321 dial feet. Needs adapting ...
The thickness and the length.
The dial feet of the 321 are longer and slightly thicker than the 861.
While it is easier to shorten the dial feet from a 321 dial to fit the 861 movement, i would think twice before doing so.
