Beryllium-copper parts? Dangerous?
Hi!
First, a little background about myself. I have started dabbling more and more with disassembling, repairing (or attempting to), and assembling watches - in particular, vintage Omega and Longines watches.
Recently, I have learned that some watches may contain parts made from beryllium-copper alloys. For example, apparently, from reading some online posts, at least some sweep seconds friction springs used in vintage Omegas may be made from a beryllium-copper alloy. Is this true? If yes, is it dangerous to fiddle with any such parts?
As you might be able to tell, I am quite obsessive over potential dangers.
I look forward to all your views - whether you are a fellow dabbler, an actual watchmaker or neither.
Best
DC
Like many hazardous materials, BeCu components are only a danger if you are grinding, welding/heating them so that dust or fumes are given off.
Many thousands of watchmakers have been handling these items for ages with no known ill effects.
BeCu is also used widely in electrical equipment and military equipment and while standard precautions are observed, there is no risk to personnel.
Edit - PS: I'm also a "watch dabbler" and a retired military weapons system specialist (aviation) and technical specialist (defence contractor/naval systems).
All previous roles encountered BeCu in one form or another.
Thank you so much for your views, Jim. I really appreciate it.
I should have clarified in my original post that I am not manipulating these parts in any major way. I am just wary whether there are dangerous if they were, say, scratched, marked or bent by other parts or watch tools.
In general, you want to avoid frequent and chronic inhalation of beryllium dust. This is generally a risk mostly for people who routinely machine parts out of pure beryllium (e.g. X-ray windows) or beryllium alloys. Beyond the general knowledge about beryllium poisoning, I think you will need to use common sense.
Thank you so much, Dan. Both your and Jim’s replies have helped me clear my mind and confirm my own views too.
