John Chris
路You forgot about the WoC dials - white on cappuccino. I've never seen a silver on fume. The two cappuccino dials I've owned, one with white subdials, the other with silver, are both clearly original in the sense of being 1969-1970ish, not service dials. Nor are they faded fumes. The tropical effect is quite different. Without confirming data from Zenith, I wonder whether trying to match runs is productive given how often dials are switched in and out of cases (I plead guilty). Sometimes you just gotta trust your eyes is what I feel. I think I can tell faded fume from unfaded cappuccino. If fading were the explanation, the ones I've seen would not be so uniform. In fact they are identical. And the only way white would change to silver would be by removing white paint to reveal a metal base, but that would eliminate the numerals, and would show up all over the place. Logic says - three different versions, all original. Plenty of other examples, particularly with the different combos found on the Fernsehers, and the De Lucas.
