GreyTime
·ROUND 3-5: My wife is "surprising" me with a wonderful 5th anniversary gift of a vintage Omega Seamaster. This is our first foray into what we would consider a more serious watch, and want to make sure we do well. This is my third thread on the matter, and we've diverted the search process some due to a suggestion from this site to a site that may be a tad pricey, but hopefully will be a better starting point from a product quality purview.
Apologies if separate threads are recommended, I thought it would be less clutter to the forum this way. I can break them up individually if preferred. I will label each as option #3, 4, and 5. I'm thinking I would prefer a mix of option 3 and 4 at a lower price point. Also, none of these have authentic straps so that will be an additional expense as well, open to suggestions in that regard. Critique and guide away, gentlemen (and ladies?)!
#3) 1959 OMEGA SEAMASTER 2938-3 SC
#4) 1963 OMEGA SEAMASTER 14760 - SC 62 (DATE)
#5) 1954 OMEGA SEAMASTER F6249
#3) 1959 OMEGA SEAMASTER 2938-3 SC: $2,050
Circa: 1959
Model: Seamaster
Caliber: 285
Jewel count: 17 jewels
Movement type: Manual wind
Case model: 2938-3 SC
Case material: Solid stainless steel
Case gasket: O-Ring rubber gasket
Crystal: Brand new Acrylic crystal
Crown: Signed
Case Diameter excluding crown: 36mm
Case length lug tip to lug tip: 44.4mm
Dial: Factory original finish
Hand type: Dauphine (original)
Strap material: Handmade vintage style genuine leather
Strap width in between lugs: 18mm
Here is an uncommon Omega Seamaster watch with center second feature. The attractive factory original dial is in excellent condition. Yellow gold tone hour indexes and original dauphine hands. Professionally serviced manual wind movement working strong and accurate. Omega caliber 285 dating this watch to 1959. The unpolished original solid stainless steel case measures a large 36mm across excluding the crown by 44.4mm lug tip to lug tip. Original signed crown. Case model 2938-3 SC. Brand new crystal and brand new case back gasket. The watch is ready for daily wear and will come with a high quality 18mm new handmade genuine leather strap.
#4) 1963 OMEGA SEAMASTER 14760 - SC 62 (DATE): $1,650
Circa: 1963
Model: Seamaster
Caliber: 562
Jewel count: 24 jewels
Movement type: Automatic wind
Case model: 14760 - SC 62
Case material: Gold plated over solid stainless steel
Crystal: New acrylic crystal
Crown: Signed
Case Diameter excluding crown: 34mm
Case length lug tip to lug tip: 41mm
Hand type: dauphine (original)
Strap material: genuine leather
Here is a stunning vintage Omega Seamaster Automatic watch. Professionally serviced Omega caliber 562 automatic movement running strong and accurate. Original signed crown. The factory original dial is in very good condition. Minor visible mark around the 5 o'clock index. Original set of dauphine hands. The original gold plated over solid stainless steel case is in very good original unpolished condition. Case model is 14760-SC 62 and measures 34mm across excluding the crown by 41mm lug tip to lug tip. The watch will come complete with a brand new 18mm high quality genuine leather strap.
#5) 1954 OMEGA SEAMASTER F6249: $1,650
Circa: 1954
Model: Seamaster
Caliber: 344
Case model: F6249
Case material: 14k gold filled
Case gasket: Flat-Ring rubber gasket
Crystal: Acrylic New crystal
Crown: Signed
Case Diameter excluding crown: 34.5mm
Case length lug tip to lug tip: 42.8mm
Up for sale is a stunning Omega Seamaster automatic watch. It is very difficult to locate a gold filled beefy lugs Omega in fine condition. The factory original finish dial is attractive and is in very good condition. Breguet numeral dial is always collectible. The case is made of 14k gold filled. The case is left in its original unpolished condition. Original signed clover crown show sign of missing cap. Brand new crystal. A new case back gasket. 18mm croco grain genuine leather strap is brand new. The case measures 34.5mm across excluding crown by 42.8mm lug tip to lug tip. The 17 jewels automatic movement has been serviced and regulated. It is an Omega caliber 344 with serial number 14116571 dating this watch to 1954. Case model F6249.
Circa: 1959
Model: Seamaster
Caliber: 285
Crown: Signed
Circa: 1963
Model: Seamaster
Caliber: 562
Crown: Signed
Circa: 1954
Model: Seamaster
Caliber: 344
Case model: F6249
Crown: Signed
