An ownership review of the Omega Globemaster, or “The Idiot Button”
Wow. A review that's truly worthy of the watch. Thanks @Longbow for taking the time to put your review together and share it here.
As a fellow engineer, I have to ask you this: what kind of info. are you presented with when you log onto Omega's web site and check the results from the METAS certification? Would you mind posting a screen capture? [with appropriate masking of any personal details, of course]
p.s. -- Thanks for the heads-up on the Idiot Button. I would have surely pressed it myself.
About AU$800 for the OEM strap & deployant, which is above my budget.
I'm thinking as an alternative, a Camille Fournet dark grey round-scale alligator strap. What do you think?
FYI - Manufacture Jean Rousseau are the OEM suppliers for Omega's leather straps, and they'll happily put something together for you similar to the way Camille Fournet will. You can even get a high-quality (though non-Omega-branded) deployant clasp from them, at perhaps 1/2 the price of the official Omega branded strap and deployant.
I'll even bet @yinzerniner knows the exact combination of material and color for the Globemaster strap
Thanks for the tip, I'll check out Manufacture Jean Rousseau.
I went to the AD to give it a go. The white is singing out to me. 9e1021ab77c41822a008c7818bbe897c.jpg ffa0bd52e74e017300a31b80e0fbf97c.jpg
Which color did you get in the end?
I have a Speedy Pro and might be looking to get a diver (after I sell my tudor bbb and sla017). So a white dial option might be nice....
I have the opaline silver dial, which looks a bit more like creamy white tbh.
RJ
Hi @Jones in LA,
I was just about to post my results (screen capture) when I noticed the Omega Copyright logo....I seem to be getting too many ear-bashings at the moment for posting stuff I shouldn't so what I will say is that the data is just a list of test criteria pass results and in the few instances where a specific timing value range is possible the actual measured value will be shown. So for example the first result shown is the test for average daily precision with my GM showing a result of +4.8s for an allowable range of 0 to +5s/day and this is indeed my experience, circa 5s/day fast.
The other result that is interesting is the deviation of the daily precision after exposure to a 15000 Gauss magnetic field which in my case was just 0.4s/day in the range 0 to 5s/day. The only result that was maybe a surprise was the variation over 6 positions which came out at 3.8s/day from a range of 0 to 12s/day. So generally a GM will always run ever so slightly fast, which is OK if you develop the habit of daily time corrections against a known good source. This is I guess a bit different than the Rolex approach of having a similar span but centred around 0, +2s and -2s which could result in the watch being generally on-time without much intervention assuming it lies overnight in varying positions.
So, nice (summary) results to have but as an engineer I would have liked to have seen a lot more detail.
Cheers
Nick
I tried the white, the blue and the white with YG bezel on at the local AD. My son with me as well. I ended up buying the white although Initially I thought going to go for the blue ....... but it didn't look as good on my wrist as the white one did. However the blue one looked better on my sons wrist. Go figure. Actual fact I really liked the white with gold bezel but since I'm retired and don't have as much need for a dressy watch I went with the white.
My point is they are all beautiful watches in their own right. So if you can, you really need to try them on to see what looks good on your own wrist.
[QUOTE= I went with the white.
Congratulations! It's a beautiful watch! Wear it in peace and happiness!
No sooner said than done! I'm glad you asked me as it was a lot of fun to prepare. Since I couldn't decide which images I liked the most you can peruse the lot. I decided to skip the RM on NATO as that would be a bit too much thread drift.
Enjoy!
Note to the observant amongst you: at least three straps are the wrong size, but they were close enough to give an impression of how the GM would look.
Great pics!
One thing I haven't seen mentioned here regarding the bracelet - it has no adjustability at the clasp, and no half links are available. The only adjustments possible are to either remove or install full size links. So whether a person likes the bracelet tight, loosy goosey, or anywhere in between, the liklihood of getting it exactly as you like it is a lot lower than with most other Omega bracelets. On my 7" wrist, I have a choice of bracelet fits - tourniquet tight, or looser than I like. The blue alligator/clasp works a lot better for me.
I knew I had forgotten something important.::facepalm1::
I can't tell you how often I thought about that issue; your right, spot on! I even commented on that in another post
https://omegaforums.net/threads/an-alternative-trilogy.63133/
I think the lack of adjustability and the rather sharp edges were the two primary reasons I was initially put off by the bracelet....which is a pity because in almost every other respect it is one of Omegas finest.
Longbow, thanks for sharing so much on this watch. Glad to have taken the time to enjoy your review.
Hi All, I'm new to the forum and to higher end watch collecting. First, props to Longbow for what is the most objective and complete review of the Globemaster anywhere on the web. (I know this for a fact because I've read them all!) I'm soon to pull the trigger on a grail, and the Globemaster is on the very short list along with the Datejust 41 and the newly redesigned Aqua Terra. I love how the Globemaster is not commonly seen, and sports a near 100% brushed look where the DJ41 and Aqua Tera have so many blingy and polished surfaces. the Globemaster would be the perfect watch for me, however the comments about the sharp bracelet and lack of adjustability greatly concern me. So too does the less than best fit and finish I am seeing where the end links meet the case. I have my heart set on a bracelet, so any more feedback regarding the bracelet is appreciated. My wrist is 6-7/8.
Hi @fourcircle,
Thanks for the kind words wrt the review.
Some thoughts on your comments above:-
At my request Omega went over the inside edge of the bracelet very lightly with a polishing wheel which cured the sharpness issue; the result is imperceptible to the eye but noticeable in comfort.
Both the new Aqua Terra and the Globemaster have none adjustable butterfly clasps, so any issues you have with this system will be the same. I don’t know if the Rolex easylink system is offered on the DJ41, you need to check.
Despite my initial misgivings I am now pretty happy with the overall comfort of the GM on bracelet combo...I‘m still wearing my GM as I write, so I guess that’s a recommendation.
The bracelet to end link to case fit and finish is in my opinion excellent. Any gaps you have seen are simply the effect of the bracelet wrapping around the wrist and opening up the links. To avoid this you would need a bigger wrist, smaller watch or different bracelet system. I can’t say that it has bothered me at all in real world daily use.
Your wrist size is a smaller than mine which means the GM is going to appear bigger. I can’t imagine the DJ41 looking right, unless you are a fan of the current “dining plate on wrist” fashion. Don’t be afraid of trying something a little smaller; you will get a more elegant look and access to all the great vintage pieces.
A question for you: do you need the date function (most people do for everyday use)? If not there are plenty of other options such as the Railmaster LE, which although heavily polished is a truly excellent watch. Or you might consider the latest Rolex Explorer I which is more tool-like. For the ultimate all-brushed look check out the new non-LE Railmaster.
If you can live with smaller watches then another one of my favorites is the vintage Seamaster 168.023, especially in Stainless Steel with the so called “Sparkle” dial...there are plenty of photos of them here on OF. Check out the posts from @JohnSteed and @styggpyggeno1 for some stunning examples. The advantages of a watch like this are that you get great everyday practicality with day and date functions, good spares availability (according to my contact at Omega) and instant street credibility in the vintage watch collecting community.
Before you do anything else, stop looking at websites and go to an Omega Boutique or Authorised Dealer and try the watches on that interest you.
Good luck!
Nick
Longbow, thanks for your reply and further intel. To answer your question, yes I must have a date, so that eliminates all no-date contenders. What initially attracted me to the Globemaster was it's unique blue dial, fuss free brushed finish, and vintage vibe. Watches in the 38 to 40 mm range fit me really well. Surprisingly, the DJ41 fits me better than a DJ36, and is surprisingly comfortable. While the 41's case fills the top of my wrist, it's lugs do not extend beyond, and the oyster bracelet shows nary a gap at any angle. The Globemaster's 39 is perfectly acceptable, but as you correctly noted above, I believe the flat lugs on my smaller 6-7/8 wrist causes the bracelet to bend revealing an objectionable gap between the 1st and 2nd links. That, combined with the sharp link issue you note and no half link adjustability, gives me purchase pause. BTW, the sharp link issue is only noted a couple of times online, so maybe it won't bother me (?) and it could be that I just might fall into the fits just right category. Alternatively, the revised Aqua Terra does have a half link, has the same 8900 movement as the Globemaster, is very versitile and presents a great value proposition at $1500 less than the Globemaster. But like the DJ41, it too has the blingy, fussy polished surfaces and I can't seem to get by the triangular shaped indices. I have located a reputable source with a manageable price for a new Globemaster who will size the watch before shipping and is willing to take back the watch if it doesn't fit me, minus a handling fee of about $175 if returned. I wonder if I might should give it a go?
Sounds like a good deal. U can try it and if not then just shipped it back to him.
Personally, the globemaster was in my sights last year, but objectively, I couldn't bring myself to buy it. I would buy a Rolex because it holds the value alot better than an Omega (IMHO). If i struck lottery and won 10 million bucks, then that would be a different story...
