An interesting repair - the "dog bite" Speedmaster
Recently saw a post on another forum about someone who was wearing their Speedmaster when they were attacked by a German Shepherd. The watch helped save his arm from significant damage, but was damaged pretty badly in the process. The owner contacted me, and since I really like these projects, I agreed to take a look to see what could be done. Here is one of the photos he sent me - the bracelet had snapped as he pulled his hand from the dog's mouth:
The dial side of the watch didn't fare quite as well as the back did:
You can see that the dog's teeth had pierced the crystal, and badly dented the dial. Now the owner didn't come out of this completely unscathed, because the underside of his wrist had a couple very deep gashes in it - he sent me a photo but I'll refrain from posting it since people may be squeamish, but I can confirm it was nasty.
When the watch arrived, the chronograph seconds hand had gone AWOL:
Two problems - the watch head damage, and the bracelet damage - the link just before the end link had bee ripped apart:
Movement is out of the case:
I had reassured the OP before he sent me the watch that there would be no movement damage from the dial being distorted, because there's really not much there to damage. The winding and setting parts are under that part of the dial - side view of how much the dial is distorted:
Underside of the dial:
The movement would run, but full wind dial down was not great:
Started on the movement service, which was mostly straightforward, so I'll only include a few photos along the way:
We had talked about trying to save the dial, and if it was possible the OP said he would like that, so he sort of had a memento of how the watch saved his wrist from more serious damage. So I set about seeing what could be done to fix this:
Fixing this damage isn't something I do all the time certainly, so I had to sort of improvise - first thought was using a pin vise on the dial foot, but I realized that wasn't going to press on the right spot to remove the severe distortion:
So I got out my staking set, and set about gently (as possible) moving the dial's material back into shape:
It was a lot of light tapping and checking...more light tapping and checking, taking it slowly and methodically. Then with some of the more acute damage flattened out as much as it could be, I started general shaping of the dial using my fingers (with finger cots) with the dial in a block did the rest:
This is the result, and I was pretty happy with it:
Carried on with the assembly:
New pushers, crown, crystal, and case back seal were installed:
The damage is still there as a reminder:
More to come on the remainder of the job...
Hello Mr All,
I always like the professionalism, pictures and explanation with the work you do…
To me, being a watchmaker like you are, is very fascinating…
Unfortunatelly because I was born and I lived in a comunist country for most of my life, there, we did not have access to watchmaking schools and knowledge about watches, etc.
All we knew at that time it was mostly about Russian watches, such as Raketa, Pobeda, etc.
But I would have liked to be able to learn about watchmaking.
Regards,
Emil
Looks like all the lume from the 2 hour marker has gone. Now we should be aware of a german shepherd with glowing teeth. 😀😀😀😀
Al, another great story ... and...
Carrying on...
So this is the state that the bracelet arrived in:
So there are generally two types of links in a bracelet, the first being the type that can be removed for sizing purposes, that are located near the clasp. The second type are fixed links, and these are sold in "strands" so there will be a strand on either side of the case. I checked to see if the bracelet still had parts available, and some links still are, but not the strands. The break in this one is in one of those strands, so with basically nothing to lose I wanted to take a shot at repairing this.
Fortunately if you look at the links closely, you can see they are folded links. You can see the seams, and the round end of the pins:
I first tried straightening the pins in place, and one snapped. The other I did manage to straighten without it snapping, but I had to remove the broken pin in order to replace it, and to do that I had to open up the seams:
The broken pin - note that it is two different diameters:
With the intact pin retracted, I could slide the center part of the link in place, and seat than pin again:
So I needed to make a replacement pin, so some measurements were taken - 0.99 mm at the large end, stepping down to 0.88 mm at the small end:
I found a pin that was the correct larger diameter, so now it was a matter of cutting down a portion of it to the smaller diameter on the lathe:
Test fitting it in the bracelet:
New pin is installed:
The links are closed up using a burnisher, and after this photo I took it to the refinishing area and used a satin finish wheel to smooth everything out, and it was hard to tell that it had even been taken apart:
Pressure testing - passed fine:
Mounting the bracelet with new Omega spring bars:
Fin:
As I said I do like jobs like this - lost causes and basket cases that I can bring back to life. It's a nice change from the same routine of regular servicing, to take something from this:
To this:
I believe the owner had a family vote to decide whether to keep the dial or not, and keeping the dial won. I've serviced completely flooded watches, the one run over by a car, and now this one, and in most cases the owners want to keep a reminder of what the watch went through - for me it's a testament to how tough these watches really are, and what can be repaired if you put your mind to it.
Hope you all enjoyed the journey, as I certainly did.
Cool repair Al…..makes me want a croc bite dial now 😗
On thinking it over ……Maybe not…..
PS. Can you PM the wrist pic.
I love reading your posts Al. Each one is dripping in your passion for watches and craftsmanship. Thank you for all you share on this forum!
I am a fan of dogs generally, but almost any breed can inflict a serious bite and some of the larger breeds especially so. Although it sounds like this was a severe bite, it would have been even worse had it not been for the watch. I had a 120 pound Old English Sheepdog for many years. He was a gentle giant, and absoulutely devoted to and protective of my infant daughter, but more than once I saw him snap a Christmas ham bone in half with those jaws. I would never allow any dog to be with a baby or child unsupervised. Cats are worse.
Just some information about the dog - it was an older dog (at least 12 years old) that the victim had met before, but was relatively new to the neighbourhood. The dog was described as well trained an obedient. The dog's owners were away on vacation, and the dog sitter accidentally let the dog out. Apparently it came over to him and was fine to get some attention, but became more stressed over time being out in fairly new surroundings without the owners present, and then lashed out.
The dog owner has taken full responsibility, even though they were not present at the time. The dog is fine...
Maybe the dog was a Daytona fan. 😲
Hi Al, glad you got this watch and customer all sorted out. I am just curious about your lathe drive belt, it looks like it’s on its last days. Is this true or is the picture a bit deceiving?
Squirrels don't like Speedmasters, maybe the same is true of German Shepherds.
Yes - it's been on it's "last days" for many years now. 😀
I just scrolled back to check that belt out and damn, I get that you miss the vintage Jaguar lifestyle though and this is as close as you can get without being stuck on the side of the road.
Brilliant!! I love that you kept the original dial and forever he will have the watch that "saved his wrist" with the appropriate scars to prove it.
Amazing work and post @Archer
Thank you
Ha! 😀
I should replace it before it snaps and whacks me in the face...
That is strange behavior by the dog. Sometimes older dogs develop dementia-like symptoms.
Seems like a good thread for a brief dog bite story.
Was playing fetch with a tennis ball and my old Chesapeake Bay Retriever. He brought it back and I mistakenly attempted to grab the ball from his mouth.🤦
At the same time I grabbed it he chomped down, with my thumb between the ball and his tooth and his tooth went through my thumb nail.
I have hit my fingers/thumbs with a hammer on many occasions, (sometimes more than once in the same spot.😟) This dog bite was worse. The pain came on just like a hammer, and then just continued to elevate above that level. Much more respect for dog bites after that.
Fortunately no dogs or watches were harmed.
Fantastic repair but horrifying that a dog can do that damage.
Ha! 😀
Precisely what I was thinking when I saw how close your left eye was to the belt!!
