- Posts
- 56
- Likes
- 78
Apparently a gold ladies' cocktail watch with a repainted dial. If it's truly gold, then it's probably not entirely fake.
J JWThank you. I'm no good at painted Omega dials. Do you know it's repainted just because it's too clean for its age?? I don't actually know it's age though....
Just remembered that I weighed it. It was 46 grams or thereabouts so quite weighty.
The redialing is pretty obvious IMO. The 'swiss made' not being straight was my first clue, though the hour markers not being straight/aligned (particularly 9 and 3) are a dead give away.
The brushed/sunburst finish and printing don't look good to me. If that is 18k, there's a lot of value in the gold. Mostly the bracelet, obviously.
J JWNoted.
Indeed, it's a heavy thing for it's size. I'm guessing the crystal and movement are only a few grams off the 46 I weighed it at. Although I'd like to think the value of the complete watch is more than it's scrap gold value?? It's actually a really pleasant piece to look at in the flesh.
FWIW, the value of the complete watch is not much more than the scrap gold value. Ladies' cocktail watches are not terribly collectible, and with the repainted dial, the extra value of the movement is negligible. And at the moment, you can get roughly $55 USD/gm of 18k scrap gold. So that watch could be worth an astronomical $1200.
J JWI've just weighed a vintage ladies Omega movement at around 3 grams. Plus the crystal. So it'll still be over 40 grams. That's around 2,200 US scrap!!
Maybe? I have a tough time thinking that the plexi crystal could make the 'swiss' tail upward, and the 'made' start quite a bit below it. It ALSO looks quite a bit 'penned' in, but I'm not positive.
I checked quite a few of the hour markers with 'the one across from it', and many of them don't seem to point correctly. 3/9 were the ones I saw immediately (the 9 is significantly 'higher', though parallel to 3, and points above the pivot by quite a bit, whereas 3 points below).
So this is very much just "things seem misaligned" to me.
J JWWell, I had another look at this piece today. Unsurprisingly, up close under the loupe, the writing on the dial looked very rough and jagged. Confirmation that it's been messed with. I didn't even bother taking the back off.
Game over!
Thanks for your help everyone
Yeah, I thought so. "OMEGA" looked goofy and inconsistent line thicknesses between the letters, but the 'swiss made' looked particularly bad in the picture.
Were you able to find out if it was gold, or gold-filled? That bracelet is something else if actual gold...
