8806 movement exposed..
Thanks again for all the helpful and enthusiastic replies. This is such a good forum.
On the other hand, if all their watches are 40mm+, and they already go to the expense of developing new movements, why not make them a bit larger? You can fit a larger inertia balance, a larger mainspring, the larger size makes it a bit easier to work on, and most of all people would feel better about getting a decent amount of metal for their money - instead of a spacer with 'metal' written on it ;-) .
They aren't...
Al is right.
And i wondered how the 8800 would fit in some small lady watches 😁
Isn't the "rule" that the smaller movements with the lower-mass balance inherently more accurate?
Tom
Tom
No, that's not a rule...the subject is complicated, and involves many different variables...inertia of the balance, beat rate, etc.
A larger balance with more inertia is more difficult to disturb, but is often found in lower beat watches. A smaller balance is more easily disturbed, but recovers it's rate quicker, and is typically in faster beat watches. Either can be very accurate depending on the situation.
If Al says it is 26mm then it is 26mm, looks like Watchbase is wrong.
Here’s a crude photo with 6 arrows, all identical in length.
The full six arrows length is [X].
Four arrows is 66% the length of [6 arrows].
Similarly, 29mm is 72% of 40mm. Put differently, 40mm will appears almost 30% larger than 29mm.
and 26mm is 65% of 40mm - shocked that Barney Rubble sh*t seems to have been right-ish
A lot of modern watches have movement spacers, the trend towards larger watches made it obligatory, especially if a company is using existing/evolved calibres that were originally meant for use in much smaller watches.
I have some vintage watches from the 50s and 60s with movements that are downright miniscule compared to today's. I can't imagine putting one into a 42mm case... The spacer would be half of the watch...
